Australia's greatest home building and renovation community providing you with access to the popular building forum, planning and budgeting tools, and the premium building directory.
About to go put in my electrical plans (double storey house) with a volume builder and have some questions. I'm happy to go wi-fi in some parts of the house like the lounge, kitchen and alfresco areas but would like Cat6 points for some equipment in the study and also for hooking up up NAS and media streamer. Maybe a network point in each room as well.
I'm thinking of having all network ports terminated into the room under the stairs where I plan to house the network switch. Is this an ideal location? I'm concerned about heat and ventilation. Are switches generally noisy if they have fans?
Also, since my estate is optical fiber enabled, I think the default plan from the builderis really something from Argus like a Hills Hub which is most likely located in the garage. How is this going to affect my plans?
Under the stairs for a double story house is a good central spot for network cabinet.
I'd suggest going two data in every room rather than one, and i'd go at least four points where you'll have TVs or anything like that. Best to overcompensate now because things are only going to require ethernet more in the future.
I don't know what the room under the stairs is like, but it might get warm, if there's an outside wall in there you might put in an exhaust fan or something. Some others on here may have better solutions for you.
Ditch the Hills hub is my suggestion, get your Cabler to do the fibre lead in straight to your cabinet under the stairs for ultimate flexibility.
_________________ Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011
Joined: 09 Jan 2009 Posts: 262 Location: Hobart, Tasmania
+1. A Hills Hub setup might appear easier initially but you lose a lot of flexibility, and really, a standard patch panel type setup is just as easy.
We have our "server closet" under the stairs and it is a little bit warmer in there, but only 3-5 degrees. Since (a) it is in the middle of the house, well insulated and (b) we are in Tassie it usually doesn't get more than about 25 degrees.
One other suggestion I will give - seal the room (ie. paint the walls with undercoat, seal the floor using bondcrete) to reduce the amount of grit (dust and plaster particles) in the area!
_________________ Built 3br house in Glenorchy, Tas in 2001 * * * Building 5br courtyard house in Lenah Valley, Tas in 2011 - Homeone thread / Blog
Nice idea, I like that one!
Joined: 11 Feb 2009 Posts: 1431 Location: >Adelaide SA<
humble wrote:
Some of the prices are just stupid tho. 48 points of cat6 across a house including rack and conduits.. 16k.
I am staring at this now, as I will want at least 2points in every bedroom, 4 in the lounge and therte, I can see it costing a bomb.
hey humble.. that price was for Cat6a... and in rural town...
most houses work ou to be around $80- $100 per run depending on the many various options...
_________________ Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal
you stalking me?
No but are you stalking me.. been here longer..
