Ive been doing some research on surround sound in a theatre. Ive heard that 7.1 suround sound is a waste of time since your players usually dont support this.
The other thing is the speaker positioning. Ive been told that your speakers should be the same height all the way around the room. I was planning ot have to large stand speakers at the front and 2 smallish speakers on the upper part of my rear walls.
What configuration have you guys gone for? And are you using 5.1?
Joined: 14 Feb 2011 Posts: 507 Location: Blue Mountains, NSW
Hi
I wouldn't get too worried about precise speaker positions - most AV receivers come with auto set up microphones that will calibrate the timing to account for your speaker positions. Even if you did set them up precisely it would require you to sit in the precisely calibrated location.
I have installed 7.1 as many modern DVDs and all Blu Ray discs include support for the extra surround channels, but 5.1 still sounds pretty good.
Paul
_________________ 5 acres in Hartley, NSW Our House Blog
Post subject: Re: Home Theatre - Speaker placement
Posted: Feb 29, 2012 10:16 pm
Joined: 11 Feb 2009 Posts: 1431 Location: >Adelaide SA<
Cable for 7.1 but at the start use 5.1
_________________ Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal
Posted: Feb 29, 2012 10:26 pm
Silver Member
Not sure I agree that 7.1 is a waste of time. I have had both and 7.1 is good, especially if you use Blu Ray. it provides more flexibility in listening. Placement wise, yes most systems can calibrate for odd speaker placement but why not research correct placement for 5.1 or 7.1 as it may not cost any more to get it approx right
Posted: Feb 29, 2012 10:36 pm
Junior Member
Yeah well that's what I thought. 5.1 will be easier to install on the back walls. If I cable for 7.1 then I will have wire hangs in the walls.
My concern for the sound was that if your speakers are the same height as your front I'd think it would sound better. I think of it as which directions the sound come from. But note taken for calibration on the setup.
My preference it up on the rear walls cause its neater, not really for sound ambience. But at the same time I want a sound system that will low you out of the water!
Posted: Feb 29, 2012 11:32 pm
Silver Member
Mount your sides and rears angled down. Some speakers are built that way to allow higher placement. Also for side and rear placements you can build columns and mount quite nicely. Do yourself a favour and check out some of the build threads on http://www.avsforum.com/avs-vb/showthre ... light=show
Posted: Mar 01, 2012 8:51 am
you don't have to have those cables pulled out or have a blank plate covering them, or just mention to your ss to tell the Gprockers not to cut holes for those ones but have plenty of photos/ measuremnts of the locations of the cabling
