Browse Forums Home Theatre & Automation 1 Aug 05, 2015 4:41 pm Hi All, After few years of being in our new place, im now ready to start and consider options for our theatre. But I do have some question for you guru's Heres a list of equipment i have in mind (I havent heard or tested any yet) Projector - Sony HW40ES Screen - 100" - Model TBC Speakers - Wharfedale diamond 5.1 package Amp - Onkyo 828 - This is still up for discussion HTPC feeding all media Questions: 1. - With our room being 4.22x3.88m, is 100" going to be ok?. Im considering having the lounge at about the 3m mark to accomodate the rear bookshelf speakers being on stands behind the lounge. 2. - How close can the bookshelfs be to the wall? I have already pre-run speeaker cables in the wall. Perhaps wall mounting teh bookshelfs would be better? 3. - With the components list above, can any recomend anything may may be more suited? Thanks for all your help Adam 3. - Re: Home Theatre Advice 2Aug 05, 2015 5:33 pm not sure if this is allowed but try posting this in AVS forums or Whirlpool forums. You will get a much better response. At 3m though 100" is probably the max you want to go. You should really go into a a store such as Big Picture people or any local store that specializes in home theatre. They will have some of this stuff setup and you can take a look at get an idea on sizes etc Re: Home Theatre Advice 3Aug 05, 2015 7:14 pm Definitely want to check out what specialists have. For your speakers you need to see if they are rear ported, if they are they will more than likely need to be further from the wall. Screen size is up-to what you want and definition. I will be having two rows with first row just over 3m back and my screen is a 160 inch scope screen. Cheers mark Re: Home Theatre Advice 5Aug 06, 2015 9:52 am Check out http://www.projectorscreens.com.au/ for screens. That's where I got mine from, and where my next larger AT screen will come from too. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 22722 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 48441 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 18808 |
