Browse Forums Building A New House 1 Apr 10, 2019 6:15 pm Anyone building a double storey home with a Maple staircase? Our staircase is stained Maple and glass. If you run your hand along the balustrade it is so rough you almost get splinters. The stain also looks patchy in the timber. Our SS has told us the painters who stain the staircase should have sanded it down however we will never be able to get a smooth finish? Is this correct? I would have thought that Designer Staircases ought to provide smooth finish in their staircases which are ready to stain without the need for further sanding. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 2Apr 10, 2019 8:47 pm Mish018 Anyone building a double storey home with a Maple staircase? Our staircase is stained Maple and glass. If you run your hand along the balustrade it is so rough you almost get splinters. The stain also looks patchy in the timber. Our SS has told us the painters who stain the staircase should have sanded it down however we will never be able to get a smooth finish? Is this correct? I would have thought that Designer Staircases ought to provide smooth finish in their staircases which are ready to stain without the need for further sanding. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As of now our staircase is rough as well and we don't believe it will be handed over like this. I have pointed out couple of time. definitely, it will have a top coat to make it smooth. Keep checking with them. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 3Apr 10, 2019 8:57 pm dany Mish018 Anyone building a double storey home with a Maple staircase? Our staircase is stained Maple and glass. If you run your hand along the balustrade it is so rough you almost get splinters. The stain also looks patchy in the timber. Our SS has told us the painters who stain the staircase should have sanded it down however we will never be able to get a smooth finish? Is this correct? I would have thought that Designer Staircases ought to provide smooth finish in their staircases which are ready to stain without the need for further sanding. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As of now our staircase is rough as well and we don't believe it will be handed over like this. I have pointed out couple of time. definitely, it will have a top coat to make it smooth. Keep checking with them. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks dany I check with them again. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19192 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 74569 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9656 |
