Browse Forums Building A New House 1 Dec 05, 2018 12:19 pm Hi Guys, We're currently building with Ross North (almost at lock up) and I'm concerned about the finish of our front porch roof (see image below). I think it's called a barge, but it looks pretty rough and can't imagine it'll look much better once painted, etc. My question is, are there better, more visually appealing options to finish this type of roof? Thanks in advance! Cheers, Chris Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 11483 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6845 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10833 |
