Anyone know how hard or easy it is to get the mains water tap moved? Now frame is up, just realised ours is right where the path needs to go to our front door.
Browse Forums Building A New House Re: Moving mains water tap - hard to do? 2Jan 10, 2018 10:00 pm Ezza78 Anyone know how hard or easy it is to get the mains water tap moved? Now frame is up, just realised ours is right where the path needs to go to our front door. Depends how far away you want to move it but more importantly whether the water company is going to be okay with it as there are regulations around this. Our tap is right in the middle of our driveway so we have to move ours. Pretty silly location to have it in the first place! Initially the water water wanted us to move it to other other side of our block which we were quoted around $2k for. But after further discussion, hoping they will agree to move it about 500mm away, which should be considerably cheaper. Our 37sq Custom Hamptons Inspired Home: http://forum.homeone.com.au/viewtopic.php?t=86931 Re: Moving mains water tap - hard to do? 4Jan 14, 2018 7:48 am Ezza78 Thanks DaniJ, so is it the council I need to speak to or south east water? Speak to the water company Our 37sq Custom Hamptons Inspired Home: http://forum.homeone.com.au/viewtopic.php?t=86931 if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4490 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1953 5 11152 |
