Browse Forums Building A New House 1 Mar 22, 2017 7:56 pm Hello Everyone, https://henley.com.au/new-homes/reserve ... ian-series I have liked Caspian 25 design from Henley Builder (though their reviews are quite bad). My land is 14m X 28m with north facing front. I would like to know if someone has built Caspian with Henley or Mainvue (sister company). I will be meeting Henley to get full quote. There are few major items to include. 1. Add Alfresco 2. Ceiling height 2720mm 3. Timber flooring (not sure about which category I should choose). I want this to be good quality. 4. Good quality Carpet Q1. How is standard inclusions that comes with Caspian? Q2. Any pros and cons about Caspian 25? Thank you. Re: Thinking to go for Henley - Caspian 25 design - any sugg 2Apr 08, 2021 12:13 am mishmu Hello Everyone, https://henley.com.au/new-homes/reserve ... ian-series I have liked Caspian 25 design from Henley Builder (though their reviews are quite bad). My land is 14m X 28m with north facing front. I would like to know if someone has built Caspian with Henley or Mainvue (sister company). I will be meeting Henley to get full quote. There are few major items to include. 1. Add Alfresco 2. Ceiling height 2720mm 3. Timber flooring (not sure about which category I should choose). I want this to be good quality. 4. Good quality Carpet Q1. How is standard inclusions that comes with Caspian? Q2. Any pros and cons about Caspian 25? Thank you. Did you end up getting the quote for Caspian 25? What was your experience isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17518 Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 10483 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13830 |
