Browse Forums Building A New House 1 Mar 19, 2017 7:43 am Hi, Everyone. We were recently done PCI. Unfortunately, we found water dropping from the ceiling after checking the water pressure on the first floor.I know this is one of the worst thing can be happening when you are building a house. Our SS said it can be fixed til handover but I really worry about the plumbing issue which might happen again after handover. Is there anyone who experienced similar situation like us? We want another plumber come to our site check to make sure everything is good. Also we want to change our plasterboard on the ceiling as it already has a watermarks. We dont want to move a new home which already has a mould. Any suggestions are welcomed! Thank you! Re: Water Leaks during PCI 2Mar 19, 2017 8:44 am Hi Fegele, Another plumbing cannot come on site if the builder is still on site. Reason is because the builders hold the insurance for the construction and if another contractor who isn't working under your builder then issues could arises even if your plumber is insured. It is expected the builder will make all necessary repairs prior to handover because the council will NOT issue an occupation certificate for the residence until everything is fixed. In addition there are certifiers and depending on who your builder is there will be an independent certifier that is appointed by council or your builder. Hope the info helps. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au Re: Water Leaks during PCI 3Mar 20, 2017 7:19 am The leak could be from plumbing or a roof leak or both however, it is unlikely that you will have a mould problem from a short term leak that has been fixed. The council has nothing to do with building inspections and mandatory inspections are done by the relevant building surveyor or building inspector but they will not pick up all defects. This is why you should have your own inspector for building stage inspections. Although you have seen your leaks I have many times found invisible leaks with thermal imaging camera Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2453 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98693 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 81728 |
