Browse Forums Building A New House 1 Mar 13, 2017 8:09 pm Hi There We are planning to build With Domaine Homes in Jordan Springs, our land registers in May 2017, We have got a Tender from Domaine homes but it looks in absence of contour /geotech report or soil test, they are provisioning for additional costs cost as listed below: 1. Salinity affected environment - $3000 2. H1 class slab- $2000 3. PA - provisional allowance, dropped edge beam,piering,rock excavation etc- $10,000 4. PA- for Bush fire attack level (BAL)-12.5 $8,500 Now, I understand that as there is no access to land so, these cost is budgetary only, the land seems to be fairly levelled as per standard site cost guidelines . My question is, has anyone has got soil test report come positive for Salinity? I understand that most builders would do H1 slab in newer estates, I am trying to understand how much of those are actually required. Can people building in jordan spring east comment on salinity Thanks in advance ----------------------------------------------------------------- Land - Oct 2016, Stamp Duty-Dec 2016, Land Registration - May 2017?? Domaine Homes - Arizona 26 - Feb 2017 Re: Additional Site cost At Jordan Spring East (Stage-2) 3Mar 14, 2017 3:26 am Arizona 26 is what we are Building. They have a display home in Ellara (Marsden Park). Their plans are good cost effective, and you can choose what you want to pay for or do it later, that's why I like them. ----------------------------------------------------------------- Land - Oct 2016, Stamp Duty-Dec 2016, Land Registration - May 2017?? Domaine Homes - Arizona 26 - Feb 2017 Re: Additional Site cost At Jordan Spring East (Stage-2) 4Mar 14, 2017 9:42 pm Hi mate I received quotes from few builders and none of them spoke about 'Salinity affected environment' cost at this stage. Probably, they will when they get access to the land and do soil test:) WRT BAL 12.5 - Basically, you must built your house that meets minimum BAL 12.5. I guess that's an additional cost you will have to bear if your house falls under 12.5 H1 Slab - Yes, builders do an upgrade after the soil test. As long as it is not 'P', you need not worry. Rock Excavation - Seems unlikely you need to pay for this. You need to wait for the soil test report. All the best! Kind regards, Vinod Re: Additional Site cost At Jordan Spring East (Stage-2) 5Mar 16, 2017 7:07 pm Hi Vinod Where are you building, salinity is common in blacktown area like Elara and marsden park, I was wondering if it is common in jordan spring too? Best Regards Randhir Singh ----------------------------------------------------------------- Land - Oct 2016, Stamp Duty-Dec 2016, Land Registration - May 2017?? Domaine Homes - Arizona 26 - Feb 2017 Re: Additional Site cost At Jordan Spring East (Stage-2) 6Mar 16, 2017 9:19 pm MR.india Hi Vinod Where are you building, salinity is common in blacktown area like Elara and marsden park, I was wondering if it is common in jordan spring too? Best Regards Randhir Singh Hi Randhir, I'm building in Stage 3a - have some time with me. Will be your neighbour in the near future:) I guess salinity might be a common thing at JSE - as the land/soil is in the flood plain area. Its good your builder has already called this out to avoid surprises later. Its likely other builders would state this once they get access to the land and do soil tests. Regards, Vinod Re: Additional Site cost At Jordan Spring East (Stage-2) 7Mar 17, 2017 1:30 pm Welcome to the party neighbor..! ----------------------------------------------------------------- Land - Oct 2016, Stamp Duty-Dec 2016, Land Registration - May 2017?? Domaine Homes - Arizona 26 - Feb 2017 Re: Additional Site cost At Jordan Spring East (Stage-2) 9Mar 24, 2017 9:41 am HI, I would like to clarify your costs as noted below; We are a transparent builder and we pride yourself in educating our clients prior to deposit. The costs noted below are common in these area's which is why we have allowed them in your tender even though the land is not yet accessible. We will remove all of the PA items listed below even after Contract signing should your reports indicate these items are not required. We can only do this once we have the required Bore Hole and Contour reports. Beware of builders that don't provide this information upfront! You only have one chance to get your new home right so go with a builder you can trust. Please let me know if you require any further assistance. 1. Salinity affected environment - $3000 2. H1 class slab- $2000 3. PA - provisional allowance, dropped edge beam,piering,rock excavation etc- $10,000 4. PA- for Bush fire attack level (BAL)-12.5 $8,500 Re: Additional Site cost At Jordan Spring East (Stage-2) 10Mar 29, 2017 6:44 am We are building with a different builder, and they have included costs for drop edge beam and a M or H class slab. We are also in a BAL zero zone so no additional costs there (but in our tender it does include BAL 12.5 inclusions which will be deducted if not required), and they include the BAL costs in their tender prices that are affected. I believe there maybe some salinity effect there as it is near South Creek, and our builder also did flag this cost to us. Re: Additional Site cost At Jordan Spring East (Stage-2) 11Mar 31, 2017 6:45 am Hello, we are building with new living homes and in zero BAL but like others we have had a H slab quoted (apparently other who have built in Jordan springs have needed this), we are building on a zero lot and a drop edge beam was required...although our SC argued with lendlease about this as other estates do not require this apparently but they insisted. Hopefully this horrid weather won't postpone things too much! Would be nice to have the land register soon Re: Additional Site cost At Jordan Spring East (Stage-2) 12Apr 20, 2017 11:34 am Just spoke to Landlease and it looks liek stage 2 is not pushed to June-July due to weather. ----------------------------------------------------------------- Land - Oct 2016, Stamp Duty-Dec 2016, Land Registration - May 2017?? Domaine Homes - Arizona 26 - Feb 2017 Re: Additional Site cost At Jordan Spring East (Stage-2) 13Apr 20, 2017 12:25 pm Yeah they told me that on Friday when I called them too. At least stage 1 looks closer to registering now than ever. Interesting to see what the new suburb name is too now that it is apparently not llandilo or Jordan springs east Re: Additional Site cost At Jordan Spring East (Stage-2) 14Apr 20, 2017 12:53 pm @MR.India The information you require is in AS2870-2011 sect 5.5 Requirements for aggressive soils HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Additional Site cost At Jordan Spring East (Stage-2) 15Apr 20, 2017 1:42 pm ----------------------------------------------------------------- Land - Oct 2016, Stamp Duty-Dec 2016, Land Registration - May 2017?? Domaine Homes - Arizona 26 - Feb 2017 Re: Additional Site cost At Jordan Spring East (Stage-2) 16Apr 20, 2017 1:51 pm @Mr.India I suggest you get your own soil test & geotech report and ask to have it credited back Construction In Bushfire zones AS3959 sect 5 Please post back if you require further Info Cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Additional Site cost At Jordan Spring East (Stage-2) 17Apr 22, 2017 4:24 pm we are building with new living homes and they have included all the above mentioned in site costs just to avoid unpleasant surprises later on. better to know the maximum price upfront. if they are not needed, price goes down. Re: Additional Site cost At Jordan Spring East (Stage-2) 18Apr 22, 2017 6:10 pm manpreet kaur we are building with new living homes and they have included all the above mentioned in site costs just to avoid unpleasant surprises later on. better to know the maximum price upfront. if they are not needed, price goes down. We are building with them too. Which design did you go for? We are stage 2 Re: Additional Site cost At Jordan Spring East (Stage-2) 19Apr 22, 2017 6:52 pm blissjohnson2 manpreet kaur we are building with new living homes and they have included all the above mentioned in site costs just to avoid unpleasant surprises later on. better to know the maximum price upfront. if they are not needed, price goes down. We are building with them too. Which design did you go for? We are stage 2 we got maple 4. and we are stage 2 as well. lot 2251 Re: Additional Site cost At Jordan Spring East (Stage-2) 20Apr 22, 2017 7:03 pm manpreet kaur blissjohnson2 manpreet kaur we are building with new living homes and they have included all the above mentioned in site costs just to avoid unpleasant surprises later on. better to know the maximum price upfront. if they are not needed, price goes down. We are building with them too. Which design did you go for? We are stage 2 we got maple 4. and we are stage 2 as well. lot 2251 We are 2033. Hopefully everything runs smoothly. The maple 4 is a nice design! Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 11583 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 13065 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 38456 |
