Browse Forums Building A New House 1 Jan 05, 2017 12:04 pm Hi guys, I am considering installing EzyJamb doors in my new townhouse. My builder mentioned it could be approx up to $800 to $1000 per door? as jamb is $300 each, installation $300 then special door another couple of hundred dollars. So I could be looking at $5k for the entire house. Any other way to achieve the same flush results? Any suggestions? Thanks Re: EzyJamb Doors 2Jan 05, 2017 1:34 pm Hi building Melbourne. I think you should get a new builder . The ezy jamb with standard hinge is about $120 per jamb. I think standard jambs are about 30-40. You use a standard hollow core door so no extra. They are easy to fit I think most Subbie carpenters charge about 90 a door to install them. You then also save on architrave. Ive used them many times and they cost no more than about $ 100-120 extra per door. Re: EzyJamb Doors 3Jan 05, 2017 6:07 pm s&cgia Hi building Melbourne. I think you should get a new builder . The ezy jamb with standard hinge is about $120 per jamb. I think standard jambs are about 30-40. You use a standard hollow core door so no extra. They are easy to fit I think most Subbie carpenters charge about 90 a door to install them. You then also save on architrave. Ive used them many times and they cost no more than about $ 100-120 extra per door. Wow thanks for this s&cgia, this is extremely useful. I really appreciate this. Our internal doors are all 2340mm x 820mm, will that be one of the reasons it is costing so much more? By any chance are you in Melbourne and know of any good carpenters to recommend? Thanks! Re: EzyJamb Doors 4Jan 05, 2017 7:11 pm Sorry in sydney:-) your builder should be able to do this. I did forget one cost which is actually setting over the jamb. I'm not exactly sure how much this costs as I've never had an itemised quote. Each Ezyjamb should take 2 guys 20 minutes a door to install roughly. Install instructions are on YouTube find a chippy and show them and they should be fine to do them. Re: EzyJamb Doors 5Jan 05, 2017 8:12 pm s&cgia Sorry in sydney:-) your builder should be able to do this. I did forget one cost which is actually setting over the jamb. I'm not exactly sure how much this costs as I've never had an itemised quote. Each Ezyjamb should take 2 guys 20 minutes a door to install roughly. Install instructions are on YouTube find a chippy and show them and they should be fine to do them. Thanks again. I will speak to my builder again and see what's going on with his pricing. Maybe he misheard something from EzyJamb. Re: EzyJamb Doors 6Jan 06, 2017 8:27 am I looked at these as they are very neat. The thing I worried about is cracking of the set where it meets the plasterboard. As doors slam due to wind or anger 😉, I was thinking that cracking along the join would be inevitable over time... or am I wrong ? we have a standard size and often we have a lot of variety to choose 0 3672 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5166 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4439 |
