Browse Forums Building A New House 1 May 13, 2016 10:54 pm Hi, Has anyone recently applied for minimum from setback through Monash council? We are building through PD and need a setback of 4.5-5.5 metres, 5.5 being the maximum we can go to. We are on an irregular size block which we have put in our argument for the minimum setback. The house to the right of us has a setback of 4.0 metres and the house on the left is at 7.7 metres. Any comments/stories would be amazing! Re: Minimum front setback 2May 14, 2016 8:40 am Download from Monash council website "adjoining comments form" and get both your neighbours to sign the form and agree to the proposed setback. They also have to initial the plans Then lodge dispensation with council. Make sure your arguments refer to the ministers guidelines which should also be available on their website. Also heaps and to list other reduced setback in the immediate area ( 5 houses either side and across the road) Should be approved if there are other homes @4m. Re: Minimum front setback 3May 14, 2016 9:44 am Thanks Narrewarren01, we are getting pd to do it but have also done our own application answering/referring to all the monash guidelines. Just haven't read more recent positive outcomes Re: Minimum front setback 4May 14, 2016 12:45 pm Most dispensation are generally approved specially when there are other similar homes Re: Minimum front setback 5Oct 17, 2016 9:07 pm Hi Sian, I'm interested to know how you went with your application? We are building in Monash also and have just had our request for reduced setback declined. Cheers, Kathleen Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15779 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8463 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3677 |
