Browse Forums Building A New House Re: Metricon Liberty 45 in Ryde NSW 221Feb 02, 2017 1:38 pm Can you please send me the course details too we want to build our retaining wall against the boundary lol ------- Metricon Aria https://ourlittlearia.wordpress.com/ Re: Metricon Liberty 45 in Ryde NSW 223Feb 10, 2017 6:15 am dulie Any closer to starting Q? Hi Dulie, the rain earlier this week in Sydney has delayed our wall (again). Hopefully we can build and finish our wall next week Btw, your house is looking awesome! Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 224Feb 10, 2017 11:19 am Thanks Q, hopefully the weather gods will be kind so you can finish off that dam wall so the real fun can begin! =D Metricon Liberty 45 in Ryde NSW 225Feb 20, 2017 10:00 pm Hi all, our retaining wall is finally progressing. Hopefully the waterproofing, ag line and backfill will be done this week and we can re-start our build with M next week Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Unfortunately it's not quite at the height we wanted but apparently the DA approval and landscape plan was based on the initial M survey plan. It turns out that the survey wasn't very accurate so the actual land level is about 20-30cm higher than shown in the M survey plan. It's likely that M referenced some old Council records to draw up the plan The private certifier would only let us build to the height shown in the survey plan which is frustrating Lesson learnt is if you need to build something (like a retaining wall) that relies on a survey plan, make sure you get a proper survey done of the site There's not much we can do at this stage so we will complete the wall at the allowed height and just get back to the house build asap.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 226Feb 20, 2017 10:03 pm Sux about the height issues! But at least this way you're getting 1 step closer to starting the real build! Re: Metricon Liberty 45 in Ryde NSW 227Feb 20, 2017 10:14 pm Q, Did you decide to do your own retaining wall after M cut your land? Assuming it was cheaper than letting M do it? I have a similar issue with out site. Re: Metricon Liberty 45 in Ryde NSW 228Feb 21, 2017 12:54 pm M recommended we do it ourselves cause M doesn't do retaining walls in NSW. Our SM said it's better to do it now rather than after the house is built cause we won't have as much room to excavate for footing once the house is built. (We only have about 1.4m on that side of the house.) Its cheaper to get the bobcat in now than to have to manually dig later if we don't have enough room later to get the bobcat in Unfortunately that delays our house build though.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 229Feb 21, 2017 12:56 pm We always wanted to get the retaining walls done asap cause it stabilises our site and our neighbour has been complaining about the risk of the fencing falling down because of the house excavations. However we were faced with M's delay costs so had to go to the construction stage asap. Now we are in the construction stage, and since the SM recommended we build the wall first, we are more comfortable taking this approach. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 230Feb 23, 2017 8:57 am Not sure if M have hit you up for that $2k delay fee but I managed to get them to wave two iterations of this due to their poor attention to detail and progressing our job through to construction. If their survey isn't 100% correct you could use that. You've nothing to loss.... Build thread: viewtopic.php?f=31&t=78995 Build thread - viewtopic.php?f=31&t=78995 Re: Metricon Liberty 45 in Ryde NSW 231Feb 23, 2017 2:48 pm Quirmeball1280 M recommended we do it ourselves cause M doesn't do retaining walls in NSW. Our SM said it's better to do it now rather than after the house is built cause we won't have as much room to excavate for footing once the house is built. (We only have about 1.4m on that side of the house.) Its cheaper to get the bobcat in now than to have to manually dig later if we don't have enough room later to get the bobcat in Unfortunately that delays our house build though.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 I would have preferred to have the option to do it ourselves. Can I ask what is that wall costing you? Ours dimensions is very similar to yours. Re: Metricon Liberty 45 in Ryde NSW 232Feb 23, 2017 3:12 pm Renman Quirmeball1280 M recommended we do it ourselves cause M doesn't do retaining walls in NSW. Our SM said it's better to do it now rather than after the house is built cause we won't have as much room to excavate for footing once the house is built. (We only have about 1.4m on that side of the house.) Its cheaper to get the bobcat in now than to have to manually dig later if we don't have enough room later to get the bobcat in Unfortunately that delays our house build though.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 I would have preferred to have the option to do it ourselves. Can I ask what is that wall costing you? Ours dimensions is very similar to yours. Hi Renman, $17k all up including materials. I think it's definitely on the expensive side. Vistadream paid significantly less for his 2 walls (even though he had to fight for it) Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Metricon Liberty 45 in Ryde NSW 233Mar 05, 2017 9:47 pm Hi all, we've finally got the wall completed, at least the footing and blocks part, and ready to hand back to M to restart our build (We are planning to do some rendering to the wall later when we do the landscaping.) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The wall was a bit shorter than we had expected but there's nothing much we can do at this stage unless we submit a variation to our DA approval. It's not something we are thinking of doing now cause it will delay the build - we might think about it later when we do landscaping and if there are other changes we need to make to the landscape plan. Unfortunately the weather forecast for the next week is rain, but at least we are now back on track Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 234Mar 05, 2017 10:05 pm Nice work! Is the wall made up of besser blocks? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Metricon Liberty 45 in Ryde NSW 235Mar 05, 2017 10:20 pm Orpheus Nice work! Is the wall made up of besser blocks? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Yeah it is, but our tradie initially waterproofed the wrong side of the wall so it looks a bit weird on the outside Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 236Mar 05, 2017 10:24 pm Quirmeball1280 Orpheus Nice work! Is the wall made up of besser blocks? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Yeah it is, but our tradie initially waterproofed the wrong side of the wall so it looks a bit weird on the outside Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Nice. We are getting the same retaining walls too! Why do tradies get a simple task wrong? It's a common thing for my build. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Metricon Liberty 45 in Ryde NSW 237Mar 06, 2017 10:40 am Excellento! Hope they get cracking on your build ASAP! Re: Metricon Liberty 45 in Ryde NSW 238Mar 06, 2017 5:25 pm Quirmeball1280 Hi all, we've finally got the wall completed, at least the footing and blocks part, and ready to hand back to M to restart our build (We are planning to do some rendering to the wall later when we do the landscaping.) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The wall was a bit shorter than we had expected but there's nothing much we can do at this stage unless we submit a variation to our DA approval. It's not something we are thinking of doing now cause it will delay the build - we might think about it later when we do landscaping and if there are other changes we need to make to the landscape plan. Unfortunately the weather forecast for the next week is rain, but at least we are now back on track Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 If you don't mind can you share the cost of the wall and the height and length. I have no idea what mine will cost. Given mine is curved and varied height I know it will be more than normal. My Journey H1 thread | viewtopic.php?f=31&t=77665 Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 Re: Metricon Liberty 45 in Ryde NSW 239Mar 06, 2017 7:13 pm Hi Nev, $17k all up including materials. I think it's definitely on the expensive side. Vistadream paid significantly less for his 2 walls (even though he had to fight for it) Our wall is about 18m long by 70cm high. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 240Mar 06, 2017 7:36 pm Thanks heaps, guess I will need to get multiple quotes. I have a mate who ran a concrete company he said he will give me some of the good ones in my area to contact. Still so far away but need to budget. My Journey H1 thread | viewtopic.php?f=31&t=77665 Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 3 6402 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10732 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8179 |
