Looks gorgeous!!! Did you custom design your facade?
C U S T O M. C O R A L. B R O N T E. 43
http://forum.homeone.com.au/viewtopic.php?t=79581
Browse Forums Building A New House Re: Clarendon Madison 37 in The Grove 121May 13, 2016 4:34 pm Looks gorgeous!!! Did you custom design your facade? C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Clarendon Madison 37 in The Grove 122May 13, 2016 4:39 pm MrsJM Looks gorgeous!!! Did you custom design your facade? C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 Sort of. We had to pick a base facade and push the "project builder" as far as we could with changes. Couldn't do everything that we wanted but changed a bit to make it a bit different. viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Re: Clarendon Madison 37 in The Grove 123May 13, 2016 4:40 pm Good on you!!! I wish we did the same. It's gonna look stunning. Can already see it has a real 'presence'!! Can't wait to see it when the scaf eventually comes down! C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Clarendon Madison 37 in The Grove 124May 13, 2016 4:41 pm MrsJM Good on you!!! I wish we did the same. It's gonna look stunning. Can already see it has a real 'presence'!! Can't wait to see it when the scaf eventually comes down! C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 Thanks at least the front is coming together! The back needs to be blocked from view viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Re: Clarendon Madison 37 in The Grove 125May 13, 2016 4:49 pm BACK DOORS Just posted on the main Clarendon thread but I'm am just so devastated. SS Confirmed the back doors must stay as they are. UNEVEN. I don't even care even I'm being dramatic, but at the moment, I don't even WANT this house. How can no one ever say, oh so your plans have even doors and so does the display home but we reserve the right to make the doors uneven. Reason? The steel beam above the door.... What does that even mean for my blinds in the inside? EHI has ordered the pelmets and roller blinds for there...anyone know if they could possibly be positioned to hide this??? The unevenness looks bad from the outside but it will be worse from the inside... viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Re: Clarendon Madison 37 in The Grove 126May 13, 2016 5:10 pm If the display has even doors and your plans have even doors then yours should too. Contact your building regulator (qbcc in qld not sure who it is in nsw) and lodge an early dispute resolution! Building a modified Madison 39 with Clarendon Homes in Tennyson homeone link: viewtopic.php?f=31&t=79106 Blog Link: https://minandb.wordpress.com/ Re: Clarendon Madison 37 in The Grove 127May 13, 2016 7:06 pm I wanna give you a hug. I don't wanna tell you 'don't worry it's not that bad' because you know what... The same thing has happened to me with my windows and I know how you feel. Particularly if it's on the plans correctly and they don't build to the plan- that's just not on! Could you actually see a steel beam or was SS playing silly buggers? Now that it's bricked I'm wondering what options there are. You could disguise it inside with a pelmet but then you lose the look of the larger window. And of course it doesn't fix the problem from the outside. If I were you I would demand from SS the technical reason as to why they must stay and then be upfront with him and tell him you're escalating it because it's not as per the plan, and speak to his manager. That's the only way I've gotten anything corrected C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Clarendon Madison 37 in The Grove 128May 14, 2016 5:54 pm MrsJM I wanna give you a hug. I don't wanna tell you 'don't worry it's not that bad' because you know what... The same thing has happened to me with my windows and I know how you feel. Particularly if it's on the plans correctly and they don't build to the plan- that's just not on! Could you actually see a steel beam or was SS playing silly buggers? Now that it's bricked I'm wondering what options there are. You could disguise it inside with a pelmet but then you lose the look of the larger window. And of course it doesn't fix the problem from the outside. If I were you I would demand from SS the technical reason as to why they must stay and then be upfront with him and tell him you're escalating it because it's not as per the plan, and speak to his manager. That's the only way I've gotten anything corrected C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 Thanks for that We knew there'd be a steel beam but because the doors are the exact same size as the Parklea display home we thought they'd be uniform like the display. Someone on the Clarendon thread said they could probably gyprock the inside to be the same, so that's a lot better but still doesn't resolve the outside... Paid a visit to the new Madison 38 display at Oran Park today and just to add insult to injury, it also has the same size stackers but they've put the aluminium strip between the brick and doors on both sides. Common sense! I love how they thought enough about it for the display but for someone's home they just don't care This is the display at oran park Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Even worse, we wanted the timber on the ceiling, were told that Clarendon is a project builder and doesn't do that!, and there's a fireplace on an internal wall which we were told was not something Clarendon did. Our SS has been great so don't want to get him offside...I'm wondering if they can take a row of bricks off the smaller side and put the aluminium strip above that door too....who knows! I wish this didn't bother me, but it's so much money and more than that though, it's our home, something where we agonized over so many little details! viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Re: Clarendon Madison 37 in The Grove 129May 16, 2016 7:59 am Oh no please you shouldn't be the one having to explain yourself. I totally understand. I'm fighting it out at the moment about my barge capping not being the correct colour! I'm sure my SS thinks I'm mad and hubby keeps saying 'doesn't look too bad don't worry' but it's not what I wanted. We shouldn't have to settle. I also found a lot of inconsistency- being told by my builder 'we don't do pivot doors, we don't do window splash backs, we don't do timber look garage doors, we don't do rebated stacker doors' and it was so frustrating because all their display homes had that stuff! That aluminium strip might be a good solution. They should absolutely so what they can to fix it to your liking C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Clarendon Madison 37 in The Grove 130May 16, 2016 8:02 am MrsJM Oh no please you shouldn't be the one having to explain yourself. I totally understand. I'm fighting it out at the moment about my barge capping not being the correct colour! I'm sure my SS thinks I'm mad and hubby keeps saying 'doesn't look too bad don't worry' but it's not what I wanted. We shouldn't have to settle. I also found a lot of inconsistency- being told by my builder 'we don't do pivot doors, we don't do window splash backs, we don't do timber look garage doors, we don't do rebated stacker doors' and it was so frustrating because all their display homes had that stuff! That aluminium strip might be a good solution. They should absolutely so what they can to fix it to your liking C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 Thanks that's exactly it, we shouldn't have to settle! Not at this stage and when so many sacrifices were made at drafting stage already. Keep fighting that capping colour! I'm sure you made a considered decision originally and so that's what you should have! viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Clarendon Madison 37 in The Grove 131May 16, 2016 4:29 pm leeleh MrsJM Oh no please you shouldn't be the one having to explain yourself. I totally understand. I'm fighting it out at the moment about my barge capping not being the correct colour! I'm sure my SS thinks I'm mad and hubby keeps saying 'doesn't look too bad don't worry' but it's not what I wanted. We shouldn't have to settle. I also found a lot of inconsistency- being told by my builder 'we don't do pivot doors, we don't do window splash backs, we don't do timber look garage doors, we don't do rebated stacker doors' and it was so frustrating because all their display homes had that stuff! That aluminium strip might be a good solution. They should absolutely so what they can to fix it to your liking C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 Thanks that's exactly it, we shouldn't have to settle! Not at this stage and when so many sacrifices were made at drafting stage already. Keep fighting that capping colour! I'm sure you made a considered decision originally and so that's what you should have! viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 That's exactly it. Even the small decisions like that had time and effort put in. What will be will be though I think. Haha it reminds me of when I got married and I wrote my own ceremony and I remember agonising for weeks over whether I wanted the celebrant to say 'you may now kiss THE bride' or 'you may now kiss YOUR bride'.... I decided to be old fashioned and went with 'THE' and so ill never forget when at the end of the ceremony she said 'you may now kiss YOUR bride!' Hahahahaha in that very second when I should have been excited to be married I was giving her daggers thinking 'lady do you know how long I agonised over that!?!?!' (Never mind the fact she pronounced my name wrong the entire service!) Story of my life hahahaha! M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Clarendon Madison 37 in The Grove 132May 16, 2016 6:38 pm MrsJM leeleh MrsJM Oh no please you shouldn't be the one having to explain yourself. I totally understand. I'm fighting it out at the moment about my barge capping not being the correct colour! I'm sure my SS thinks I'm mad and hubby keeps saying 'doesn't look too bad don't worry' but it's not what I wanted. We shouldn't have to settle. I also found a lot of inconsistency- being told by my builder 'we don't do pivot doors, we don't do window splash backs, we don't do timber look garage doors, we don't do rebated stacker doors' and it was so frustrating because all their display homes had that stuff! That aluminium strip might be a good solution. They should absolutely so what they can to fix it to your liking C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 Thanks that's exactly it, we shouldn't have to settle! Not at this stage and when so many sacrifices were made at drafting stage already. Keep fighting that capping colour! I'm sure you made a considered decision originally and so that's what you should have! viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 That's exactly it. Even the small decisions like that had time and effort put in. What will be will be though I think. Haha it reminds me of when I got married and I wrote my own ceremony and I remember agonising for weeks over whether I wanted the celebrant to say 'you may now kiss THE bride' or 'you may now kiss YOUR bride'.... I decided to be old fashioned and went with 'THE' and so ill never forget when at the end of the ceremony she said 'you may now kiss YOUR bride!' Hahahahaha in that very second when I should have been excited to be married I was giving her daggers thinking 'lady do you know how long I agonised over that!?!?!' (Never mind the fact she pronounced my name wrong the entire service!) Story of my life hahahaha! Hahaha it's sometimes a curse over thinking things and wanting things to be perfect viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Re: Clarendon Madison 37 in The Grove 133May 22, 2016 10:30 am WEEK 14 brick cleaning commenced upper storey complete. Next week the scaffolding should start coming down and down pipes will go in. Can't wait to see my hip roof go on! Our meeting with our SS was postponed to next week because we couldn't be onsite when they were cleaning bricks. So another week to wait for our door height solution Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Re: Clarendon Madison 37 in The Grove 134May 22, 2016 11:10 am You are pretty much exactly where we are now so your SS has really pushed things along!!! Clarendon Madison 37 in The Grove 135May 25, 2016 7:51 am KLB You are pretty much exactly where we are now so your SS has really pushed things along!!! He has been quick! We are hot in your heels viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Re: Clarendon Madison 37 in The Grove 136May 27, 2016 9:02 pm WEEK 15 Rendering! So we had our meeting on site with our SS today.... We were thrilled and surprised when we turned up and the rendering had been done to the corbeling and pillars! Love it so much! Our SS explained that our finished floor height, steel beam due to the extra large door and the recessing of our doors meant that there was nothing that could be done with the big door. I showed him the pictures of the Parklea and Oran Park Madison displays with even brick heights above the doors...I asked if maybe he can take a row of bricks off the top of the smaller door and then both doors can have an aluminium strip above. So now we wait to hear what the brickie says if it's not possible then there's nothing that can be done trying not to give up hope. Just so frustrating because we would never have done the stacker doors had we known On a plus note, our internal door that admin refused to upgrade can be increased height so all 4 hall doors will be the same height thank goodness! Also, our estimated date of completion is late September/early October. Let's hope it's somewhat sooner because after 14 months living with my mum and sister and only mums ensuite bathroom in working order we need our house! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Re: Clarendon Madison 37 in The Grove 137May 30, 2016 5:16 pm Just been reading through your thread and sorry to see the troubles you are having with the stacker door heights. I am also looking at the stacker doors, and whilst they won't be next to each other they are all in the same room and I would want them the same height. My question is that you mention you had the doors "recessed". Was this in to the slab or something different. And was the purpose of redesign the door to make it so the " track" of the stacker door is flush with your finish floor height? Just trying to understand what options are available with the door installs. Thanks Clarendon Madison 37 in The Grove 138May 30, 2016 7:30 pm Cend15 Just been reading through your thread and sorry to see the troubles you are having with the stacker door heights. I am also looking at the stacker doors, and whilst they won't be next to each other they are all in the same room and I would want them the same height. My question is that you mention you had the doors "recessed". Was this in to the slab or something different. And was the purpose of redesign the door to make it so the " track" of the stacker door is flush with your finish floor height? Just trying to understand what options are available with the door installs. Thanks Hi Our problem is that one door was so big it needed a steel beam above it rather than a timber one. Check your plans. If it says steel beam then I would double check with your SS that the brick height will be the same above both doors. They can do this by placing an aluminium strip above both doors. I just don't know if they can do it retrospectively for us. From inside, we are told the gyprock will be the same height. We recessed the doors into the slab so there is a very minimal to no step and the floor flows smoothly inside to outside. Hope that's helps viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 Re: Clarendon Madison 37 in The Grove 139May 30, 2016 7:35 pm Sorry to hear that the solution isn't as we hoped. Fingers crossed on the work around! Your house is looking fab! I'm a bit worried as our contract end date is last week of sept and we are still at frame stage haha. I really love your facade! C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Clarendon Madison 37 in The Grove 140May 30, 2016 7:38 pm MrsJM Sorry to hear that the solution isn't as we hoped. Fingers crossed on the work around! Your house is looking fab! I'm a bit worried as our contract end date is last week of sept and we are still at frame stage haha. I really love your facade! C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 Thanks. I'm still holding out hope! Haven't been told no YET! Haha. I hope your builder is on to fixing your issues! I'll keep my fingers crossed for end of September for you viewtopic.php?f=31&t=82062 Madison 37 - site start 16.2.16 the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 7118 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8232 |
