Browse Forums Building A New House Re: KDR Sekisui House - St George 421Feb 15, 2017 4:50 pm Unlikely to matter. They will either cut it down to slab level and join whatever is above it internally, or put some sort of sleeve over it and connect the upper pipe into the sleeve. Where abouts is that pipe - do you know what it is for? Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR Sekisui House - St George 422Feb 15, 2017 9:25 pm clintdb Unlikely to matter. They will either cut it down to slab level and join whatever is above it internally, or put some sort of sleeve over it and connect the upper pipe into the sleeve. Where abouts is that pipe - do you know what it is for? This one is on ground floor powder room, will be in the middle of garage wall and powder room wall. not sure if this pipe/out let for upstairs WC. May be for powder room vanity drain? Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: KDR Sekisui House - St George 424Feb 15, 2017 9:40 pm shazaw clintdb Unlikely to matter. They will either cut it down to slab level and join whatever is above it internally, or put some sort of sleeve over it and connect the upper pipe into the sleeve. Where abouts is that pipe - do you know what it is for? This one is on ground floor powder room, will be in the middle of garage wall and powder room wall. not sure if this pipe/out let for upstairs WC. May be for powder room vanity drain? Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Your "stack" (the pipes that run waste from the upstairs toilet/shower/basins etc and connects down to your ground floor services)) is in your laundry (according to your plans anyway). I would guess that that particular pipe is for your toilet in the powder room. Although it does seem very close to the wall - normally the wall to the garage sits on the higher part of the slab (the powder room), not on the lower part (the garage itself). Otherwise, it could be more of a "conduit" where they run the hot and cold water pipes under the slab to get across to the kitchen - that is, it won't take actual water, but just be used to run the water pipes to other parts of the house. Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR Sekisui House - St George 426Feb 16, 2017 6:52 am shazaw Colours for kitchen selection. Silestone : White Storm for cook bench top Silestone : Cemento Spa for island bench top ( grey ) Capboards : Saren grey Silk finish Window frame: woodland grey Wall : June fog Timer : bamboo - Driftwood ? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build Thread : viewtopic.php?f=31&t=81624 Your selections look fabulous. Can't wait to see it come together. Re: KDR Sekisui House - St George 427Feb 16, 2017 8:12 am Yep, if I were to guess, I would say that one is the "conduit" for other pipes - but it is only a guess. Regardless, I wouldn't be concerned as it is likely that the pipe will be cut down to floor level anyway. The one on the left looks like the toilet waste and the one on the right looks like the floor waste. Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR Sekisui House - St George 428Feb 16, 2017 8:50 am clintdb shazaw This is powder room area. the middle pipe is the one with damage. Yep, if I were to guess, I would say that one is the "conduit" for other pipes - but it is only a guess. Regardless, I wouldn't be concerned as it is likely that the pipe will be cut down to floor level anyway. The one on the left looks like the toilet waste and the one on the right looks like the floor waste. Hi clintdb, If that pipe is for conduit, I wonder if they have forgotten to laid pipe for vanity waste. We do have vanity unit next to the toilet in the power room, I do have a feeling this is for vanity waste. I do hope that they will do good job at joining so water don't leak out from floor. As always thank you for your input, much appreciated. Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: KDR Sekisui House - St George 429Feb 16, 2017 9:04 am shazaw clintdb Yep, if I were to guess, I would say that one is the "conduit" for other pipes - but it is only a guess. Regardless, I wouldn't be concerned as it is likely that the pipe will be cut down to floor level anyway. The one on the left looks like the toilet waste and the one on the right looks like the floor waste. Hi clintdb, If that pipe is for conduit, I wonder if they have forgotten to laid pipe for vanity waste. We do have vanity unit next to the toilet in the power room, I do have a feeling this is for vanity waste. I do hope that they will do good job at joining so water don't leak out from floor. As always thank you for your input, much appreciated. Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Yes, it certainly could be for that. They would put a reducer on it (the vanity waste would only be a 40mm or 50mm pipe). I wasn't quite sure as often the vanity waste goes to the corner of the room where the vanity is - that way they don't have to try and guess where to put the waste point (it may end up on the "outside" of the vanity unit if the vanity is smaller than expected). If it's in the corner (and the vanity is pushed into the corner) then it doesn't matter how big the vanity is, the waste will always be underneath it Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR Sekisui House - St George 430Feb 16, 2017 9:47 am shazaw Colours for kitchen selection. Silestone : White Storm for cook bench top Silestone : Cemento Spa for island bench top ( grey ) Capboards : Saren grey Silk finish Window frame: woodland grey Wall : June fog Timer : bamboo - Driftwood ? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build Thread : viewtopic.php?f=31&t=81624 The interior designer " Kara " from Burbank was very helpful. While driving to the colour studio we were excited as well as feeling a bit dreadful with dealing new colour consultant. Our appointment was only for 1 hour , but we ended up 4 hours from 11am to 2pm. She took us step by step explaining how design works with colours and focal points. Her advice was excellent, we were very happy with our new colours range. If any one going to build with Burbank, we do highly recommend " Kara". Because we have a large island bench in the kitchen... this becomes first focal point from standing at the hallway looking into open plan kitchen. The colour for island bench is dark grey stone... when the eyes flow towards the cook top area ....we see the kitchen window splash back, this is the second focal point which looks out to vertical garden out side. The colour of dark grey from island bench is pick up by the colour of kitchen window frame ( woodland grey) because the window splash back becomes the second focal point the surrounding cabinets and cook top bench needs to be tone down... hence the white stone for cooking bench and Saren grey for cabinets ( in the white colour range but goes with both island bench stone and cooking bench stone). Kara even advised on the colour of the flooring even we are doing flooring after hand over. We are very happy with new our new selections. Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: KDR Sekisui House - St George 431Feb 16, 2017 1:16 pm shazaw Powder room, WC, Guest Bathroom colour : stone top : Arden Blue Vanity unit : Paperbark silk finish Flooring : grey Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build Thread : viewtopic.php?f=31&t=81624 Kara also suggested that we pick colour tone of kitchen island bench top to have connection for powder room and Guest room's ensuite. I wanted the powder room to add glamour so we have chosen dark patchies pattern with a hint of grey showing on the stone which is "Arden blue " ( the far right dark colour) adding "Paperbark silk finish" to vanity unit. We don't have full tiles to ceiling but tiles to 1.2m wall height, this allows us to hang a painting in the powder room. The Guest room's ensuite will have same colour with tiles from floor to ceiling. Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: KDR Sekisui House - St George 432Feb 16, 2017 1:57 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ While going through the previous colour range Kara noticed there are too much dark colours at the front of the house. The brick is dark brown, the garage roller door is dark, the window frames are dark, the balcony slats are dark and the front entry door and the balcony door are dark colours too. So she suggested to us to break the dark colour by changing the front entry door and balcony door to lighter colour. By doing so balcony slats will pop out. Yes I must admit I didn't see that before... glad she has pointed that out to us. Otherwise we will only find out after the house build. Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: KDR Sekisui House - St George 433Feb 17, 2017 10:37 am Burbank no longer offer Blanco canopy rangehood, all our appliances are now SMEG. Previously ( under Sekisui's contract ) all appliances were Blanco.
I just wants all appliances to be same brand. I don't think there are any difference between the two brands. SMEG 90cm canopy rangehood. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ SMEG 90cm oven Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ SMEG 90cm gas cooktop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: KDR Sekisui House - St George 434Feb 17, 2017 11:02 am All bathrooms basin changed from square Semi-recessed basin to SEIMA NIMOS round 475DIA
Not sure which one will look better but round ones will be easy to clean. Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: KDR Sekisui House - St George 435Feb 17, 2017 5:22 pm As you are all aware that we wants to have extra water taps and gas bayonets.
Now we have pricing from our plumber. Did any one add on extra water taps and gas bayonets? Do you thinks prices below are correct? 1. External water tap for garden $150 2. Internal Gas Bayonet $300 3. Internal water tap for fridge $130 4. Internal water outlet/tap for washing machine $130 5. Water sub meter for outdoor living $80 6. Water Main line tap for outdoor living $120 7. Gas mainline switch for outdoor living $160 Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: KDR Sekisui House - St George 436Feb 17, 2017 6:23 pm shazaw As you are all aware that we wants to have extra water taps and gas bayonets. Now we have pricing from our plumber. Did any one add on extra water taps and gas bayonets? Do you thinks prices prices below are correct? 1. External water tap for garden $150 2. Internal Gas Bayonet $300 3. Internal water tap for fridge $130 4. Internal water outlet/tap for washing machine $130 5. Water sub meter for outdoor living $80 6. Water Main line tap for outdoor living $120 7. Gas mainline switch for outdoor living $160 Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 High'ish, but not completely ridiculous. In some respects though, it doesn't matter if it's expensive or not. You just have to answer the following: 1) Could you get it done cheaper after the house is built (if you could even get some of them done at all). 2) Is it worth it for me? If the answer to (1) is No and the answer to (2) is Yes, then get them done Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR Sekisui House - St George 437Feb 17, 2017 7:59 pm Fyi our extra outside taps were a bargain at $40 Re: KDR Sekisui House - St George 438Feb 17, 2017 8:07 pm Hey Shazaw I should start my own thread hey.... Good to know smeg is still used, they had those same 900mm smeg items & microwave for us. We had to change to a&l and Bristile too. No issue though it's the same profile - prestige. what brick supplier did you have selected? We had PGH, hoping we don't have to re-select as I think PGH is part of boral Upgrade prices seem to be have changed a little but like Clint said depends on your options. We paid 40 for external tap, 197 for external gas but 250 for additional washing machine tap Re: KDR Sekisui House - St George 439Feb 17, 2017 9:13 pm clintdb High'ish, but not completely ridiculous. In some respects though, it doesn't matter if it's expensive or not. You just have to answer the following: 1) Could you get it done cheaper after the house is built (if you could even get some of them done at all). 2) Is it worth it for me? If the answer to (1) is No and the answer to (2) is Yes, then get them done Thanks Clintdb, I'm going ahead with adding all these items now. If we leave these items to do later... for surer will never happen. Definitely extra gas bayonets must added in now as these items will not be easy to do later. 1. External water tap for garden $150 each - one near the Electric meter box at the front of the house next to study - one at alfresco - for vertical garden 2. Internal Gas Bayonet $300 each ( this one is on high $$) - one for ground floor study room, will be easier to heat these rooms without using air con during winter - one for first floor living room.....most likely I will be in this room a lot during winter 3. Internal - water tap for fridge $130 - don't have a fridge required tap now...may be later 4. Internal - water outlet/tap for washing machine $130 5. Water sub meter for outdoor living $80 6. Water Main line tap for outdoor living $120 7. Gas mainline switch for outdoor living $160 Now we have to do same for electrical..... recheck every room Build Thread : viewtopic.php?f=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37139 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19096 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13442 |
