No rest fir the wicked hey! Lol
Haha love it, demand a copy to see if you signed!! Just for a laugh
Browse Forums Building A New House Re: Building Metricon Glendale 42 Limited Edition in Geelong 2201Feb 08, 2017 3:34 pm kylz4 Now need to work out our balustrade for balcony! Piers look too short, and I mentioned it to sm months ago but he said glass would come higher than piers and the metal pole that runs behind the glass would connect to timber post instead of pier. After checking plans the pole is supposed to attach to pier and the pier is supposed to be higher than glass. SM told build advocate that the plans were updated to what he had told us but we've never signed off in anything!!! No rest fir the wicked hey! Lol Haha love it, demand a copy to see if you signed!! Just for a laugh Re: Building Metricon Glendale 42 Limited Edition in Geelong 2202Feb 08, 2017 3:41 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Supposed to be like that! As you can see pier sits quite a bit above glass. Considering pier is only up to my hips I don't think it's right!!! Will look crap if they try and extend pole over to timber post instead of making piers higher!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building Metricon Glendale 42 Limited Edition in Geelong 2203Feb 08, 2017 3:46 pm Yup you have the same issue as mine but with both piers. The brickies measured the height of the piers incorrectly (from the ground) instead of from the slab height. It's a major issue so the brickies need to come back. Also, the scaffold needs to come back for the brickies to do the work. See my earlier post on this issue. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2204Feb 08, 2017 3:48 pm kylz4 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Supposed to be like that! As you can see pier sits quite a bit above glass. Considering pier is only up to my hips I don't think it's right!!! Will look crap if they try and extend pole over to timber post instead of making piers higher!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That absolutely sucks!!! They better correct it. Re: Building Metricon Glendale 42 Limited Edition in Geelong 2205Feb 08, 2017 3:48 pm Yes we just worked out last night what has caused the issue, brick height from ground which is quite a bit below slab! Wish he'd listened earlier when I said it when scaffolds were still up!!! Re: Building Metricon Glendale 42 Limited Edition in Geelong 2206Feb 08, 2017 3:50 pm kylz4 Yes we just worked out last night what has caused the issue, brick height from ground which is quite a bit below slab! Wish he'd listened earlier when I said it when scaffolds were still up!!! Plus the current height of piers is a safety issue as its very low..... no climbing over pls.... @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2207Feb 08, 2017 4:00 pm kylz4 Yes we just worked out last night what has caused the issue, brick height from ground which is quite a bit below slab! Wish he'd listened earlier when I said it when scaffolds were still up!!! What a knob!! He could've @ least looked into it. Re: Building Metricon Glendale 42 Limited Edition in Geelong 2208Feb 11, 2017 12:16 pm Building Metricon Glendale 42 Limited Edition in Geelong 2209Feb 11, 2017 12:40 pm Looking gorgeous Kylz Well worth your change, made your stairs 100x better Can't wait to see your finishing touches. So exciting seeing all my neighbours on fixing Stage. Makes us even more excited waiting for our turn. Our recent inspection has slowed our progress a bit. They need to do some rectifications but apart from that our inspector said overall it is a good build to date solar panels are up and heating ducts all installed. Re: Building Metricon Glendale 42 Limited Edition in Geelong 2210Feb 11, 2017 4:20 pm Thanks Emmz, I agree, 100 times better Just noticed looking at pics that they have put the heat controller for zone 2 in the study instead of where we had requested it! Not sure if they'd even be able to move that now!!?? Don't know why they put it where they wanted to That's great there were only a few things picked up at inspection Emmz, I'm sure your SM will be all over it and get it fixed asap for you and then you'll know your house is perfect Re: Building Metricon Glendale 42 Limited Edition in Geelong 2211Feb 11, 2017 4:58 pm kylz4 Thanks Emmz, I agree, 100 times better Just noticed looking at pics that they have put the heat controller for zone 2 in the study instead of where we had requested it! Not sure if they'd even be able to move that now!!?? Don't know why they put it where they wanted to That's great there were only a few things picked up at inspection Emmz, I'm sure your SM will be all over it and get it fixed asap for you and then you'll know your house is perfect I think it will ok for heating. Our consultant placed ours in study which zoned bed 4,5 and study and other control is leisure, 2,3. I remember I asked same question but it's linking to those areas. But double check if your unsure. Yes so true, and reassurance when they check our next stage they re-inspect those areas Waiting for our next stage in the build. Re: Building Metricon Glendale 42 Limited Edition in Geelong 2212Feb 11, 2017 7:07 pm kylz4 Thanks Emmz, I agree, 100 times better Just noticed looking at pics that they have put the heat controller for zone 2 in the study instead of where we had requested it! Not sure if they'd even be able to move that now!!?? Don't know why they put it where they wanted to That's great there were only a few things picked up at inspection Emmz, I'm sure your SM will be all over it and get it fixed asap for you and then you'll know your house is perfect Pretty sure they can't move it Kylz. Love the white cupboards! @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2213Feb 11, 2017 7:08 pm Looking nice Kylz... Re: Building Metricon Glendale 42 Limited Edition in Geelong 2214Feb 11, 2017 7:55 pm Orpheus kylz4 Thanks Emmz, I agree, 100 times better Just noticed looking at pics that they have put the heat controller for zone 2 in the study instead of where we had requested it! Not sure if they'd even be able to move that now!!?? Don't know why they put it where they wanted to That's great there were only a few things picked up at inspection Emmz, I'm sure your SM will be all over it and get it fixed asap for you and then you'll know your house is perfect Pretty sure they can't move it Kylz. Love the white cupboards! @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Yeah that's what I thought, except to opposite side of that wall I guess. Just been arguing with hubby, I think it probably works better in study anyway as that room will be used daily, he wanted it out in hallway area but I said to get up to heat in there study would end up too hot! Thoughts?? Thanks re white cupboards, I love all white kitchens can't wait to see it with the floorboards to add some warmth How small does it look from the family window haha Thanks RegVic!! Re: Building Metricon Glendale 42 Limited Edition in Geelong 2215Feb 11, 2017 7:58 pm kylz4 Orpheus kylz4 Thanks Emmz, I agree, 100 times better Just noticed looking at pics that they have put the heat controller for zone 2 in the study instead of where we had requested it! Not sure if they'd even be able to move that now!!?? Don't know why they put it where they wanted to That's great there were only a few things picked up at inspection Emmz, I'm sure your SM will be all over it and get it fixed asap for you and then you'll know your house is perfect Pretty sure they can't move it Kylz. Love the white cupboards! @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Yeah that's what I thought, except to opposite side of that wall I guess. Just been arguing with hubby, I think it probably works better in study anyway as that room will be used daily, he wanted it out in hallway area but I said to get up to heat in there study would end up too hot! Thoughts?? Thanks re white cupboards, I love all white kitchens can't wait to see it with the floorboards to add some warmth How small does it look from the family window haha Thanks RegVic!! Yes yr kitchen looks tiny @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2216Feb 11, 2017 7:58 pm Emmz70 kylz4 Thanks Emmz, I agree, 100 times better Just noticed looking at pics that they have put the heat controller for zone 2 in the study instead of where we had requested it! Not sure if they'd even be able to move that now!!?? Don't know why they put it where they wanted to That's great there were only a few things picked up at inspection Emmz, I'm sure your SM will be all over it and get it fixed asap for you and then you'll know your house is perfect I think it will ok for heating. Our consultant placed ours in study which zoned bed 4,5 and study and other control is leisure, 2,3. I remember I asked same question but it's linking to those areas. But double check if your unsure. Yes so true, and reassurance when they check our next stage they re-inspect those areas Waiting for our next stage in the build. Thanks Emmz, I think it should be better there now that I've thought about it, hubby not convinced! Re inspection of the issues is great!! Can't wait to see your next stage too! Have there been many delays with brickies in your area? Re: Building Metricon Glendale 42 Limited Edition in Geelong 2217Feb 11, 2017 9:02 pm kylz4 Emmz70 kylz4 Thanks Emmz, I agree, 100 times better Just noticed looking at pics that they have put the heat controller for zone 2 in the study instead of where we had requested it! Not sure if they'd even be able to move that now!!?? Don't know why they put it where they wanted to That's great there were only a few things picked up at inspection Emmz, I'm sure your SM will be all over it and get it fixed asap for you and then you'll know your house is perfect I think it will ok for heating. Our consultant placed ours in study which zoned bed 4,5 and study and other control is leisure, 2,3. I remember I asked same question but it's linking to those areas. But double check if your unsure. Yes so true, and reassurance when they check our next stage they re-inspect those areas Waiting for our next stage in the build. Thanks Emmz, I think it should be better there now that I've thought about it, hubby not convinced! Re inspection of the issues is great!! Can't wait to see your next stage too! Have there been many delays with brickies in your area? Our neighbours bricklayer said that it's been full on for them. At the moment I don't see any delays with them. Singles have been knocked out in 2-3 weeks looks like every M home on that stage is getting bricked. Hoping all tradies will be free when it gets to ours Re: Building Metricon Glendale 42 Limited Edition in Geelong 2218Feb 11, 2017 9:09 pm Only issues we're having is our timber is getting stolen so they need to reorder supplies For some reason I can't see our living room stacker doors onsite?? Probably stolen Re: Building Metricon Glendale 42 Limited Edition in Geelong 2219Feb 11, 2017 9:12 pm Emmz70 Only issues we're having is our timber is getting stolen so they need to reorder supplies For some reason I can't see our living room stacker doors onsite?? Probably stolen Oh crap, we have extra timber at our place....could it be yours?? what's the serial number of yr timber so I can verify with mine? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2220Feb 11, 2017 9:31 pm Emmz70 Only issues we're having is our timber is getting stolen so they need to reorder supplies For some reason I can't see our living room stacker doors onsite?? Probably stolen Oh geez lol, scumbags everywhere!!!!! Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 11783 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9160 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19341 |
