Browse Forums Building A New House Re: Simonds CLEO Melbourne 41Aug 13, 2015 9:23 pm Inspector found no door stop on balcony French door and when opening they might hit the wall For The left hand side it is possible to install a door stop, but for the right hand side, the door might hit the brick wall before it can stop... I don't know how to explain... Hope that image makes sense Wondering is it possible to flip the door.. Re: Simonds CLEO Melbourne 42Aug 13, 2015 9:38 pm What is wrong with these three pictures shara? I understand what you meant about no door stop on balcony door. Simonds will probably offer you a solution. But I'm extra curious about that first picture above. Is that black stuff mould? Is that under your stairs, in the laundry or toilet? Re: Simonds CLEO Melbourne 43Aug 16, 2015 12:04 pm The first one is incomplete painting under the cabinet in PDR. Ensuite and bathroom have the the same issues. The second one is the linen cupboard shelf. The support is broken. Third one is the garage wall. Re: Simonds CLEO Melbourne 44Aug 16, 2015 3:29 pm QA inspection is a very very very important task. My hubby and I have picked up numerous defects but there still are many things we couldn't find. Luckily we have Darbecca and Bret is a reliable inspector. Very impressive. We have found numerous issues such as the painting, mortar, brickworks, missed caulking and scratching things. They are so boring and easy to observe. I wanna show the some big issues which 'woooooow' me a lot Bret noted that defects and also listed the relevant manner. I hope they can help someone will have a QA inspection afterwards. The soaker pressure flashings to the dwellings walls have not been secured at 100 mm centres. Gutter to the garage has been damaged. There are a large scratch to this section. The brick over hang to the dwelling needs to be supported. The BCA, part 3.2.2.7 calls for a maximum overhang of 15 mm. Step in the brick sill to the entry is not in a straight position. The weep holes on the dwelling appear to be blocked to the back last ¾ of a large number. As per AS 4773.2, clause 8.2.2, bricks may only overhang a lintel by a maximum of 25 mm. On several windows we detected overhang exceeding this allowance. The tops and bottoms of all external timber doors and all internal wet area doors must be sealed to comply with the inserted. ( I love this little mirror! ) The powdercoat finish to the rear sliding door frame section has been damaged, exposing the raw aluminium, which cannot be correctly repaired on site and will have to be replaced. There are a number of bowed walls (B)/out of square walls (OOS)/out of alignment walls (OOA) and ceiling lining out of level (C-OOL) in the home that exceeded the allowance of 4 mm tolerance over 2 m. The graded sewer pipes installed in the return air void have not been supported at the maximum 1200 mm spacings. The ducted heating air return has not been installed in a manner that is “Air Tight”. If I can see batts and gap, and in some cases the bottom side of a roof tile, then it is clearly not “Air Tight”. Bathroom - the bath hob is showing out of level by about 8 mm in 2.0 m. The timber floors to the dwelling run out of level up to 9 mm in places. I checked several areas on the dwelling and it was clearly discernable the out of level floor with the direction of fall clearly defined. Re: Simonds CLEO Melbourne 47Aug 21, 2015 12:23 am Hey Shara, this is really good information, thanks for sharing. Couple of questions for you please? 1-Did you or your building inspector present this information to your builder? 2-If the inspector did, does he have any power to enforce them to rectify? 3-How did/is builder respond/responding? Looking forward to hearing this gets fixed well for you. All the best. Thank you Re: Simonds CLEO Melbourne 49Aug 27, 2015 4:54 pm tom_air Thanks for posting the problems and the relevant information, definitely helps us to make notes of what to look out for. Was that it for the issues or were there more? Hi tom air, Actually our inspector have found totally 54 defects and he offer a 47 pages report to us. And also we found other defects by ourselves. I think some defects are easy to find, so I just show something hard to find by ourselves. Are you building your house too? Re: Simonds CLEO Melbourne 50Aug 27, 2015 5:22 pm TomCat Hey Shara, this is really good information, thanks for sharing. Couple of questions for you please? 1-Did you or your building inspector present this information to your builder? 2-If the inspector did, does he have any power to enforce them to rectify? 3-How did/is builder respond/responding? Looking forward to hearing this gets fixed well for you. All the best. Thank you Hi TomCat, With pleasure 1. Brett pointed out the major issues face to face with our S.S. ( our S.S. was a little bit embarrassed ) and he sent us the 47 pages report. He didn't send it directly to S.S.. 2. On QA inspection S.S. give us a blue tags to mark defects. Just in case of our poor memory, we took lots of photo too. So we used these photo to make an additional 33 pages report by ourselves. Since there are too many issues, we write a complain letter email to SS and CSO attached inspector's report and our additional report. 3. However our CSO is on her holiday! S.S. no reply but we found his team started to fix some issues last week. We called SS and booked an inspection (not the final inspection) tomorrow. Hope all things going well. Re: Simonds CLEO Melbourne 51Aug 27, 2015 5:35 pm Megera shara - Have you had any other inspections before this (like at frame stage/etc)? Thanks for sharing your pictures! Hi Megera, I regret that we didn't find them. I think we should do two-three times third part inspection if we could. But we thought it cost too much and we're too busy. After all, we're so happy that we got Darbecca to inspect our house. I think it is worth to do so. Re: Simonds CLEO Melbourne 57Sep 26, 2015 7:14 am Re: Simonds CLEO Melbourne 58Sep 26, 2015 2:29 pm Excellent Shara. I love your floor tiles. We have similar ones. How did Simonds fix the bricks overhanging the slab? Re: Simonds CLEO Melbourne 59Oct 11, 2015 2:08 pm They didn't fix them. Ss said it is safe just as the other houses they build. Simonds CLEO Melbourne 60Oct 11, 2015 2:12 pm A big issue comes today! Water is leaking from the ceiling of the toilet in ground foor... How to post a video here? I do enjoy the drama:-D In his latest two videos he has started bringing security guards to site, I am waiting for the punch on to begin lol 6 45547 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9793 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16150 |
