Browse Forums Building A New House Re: J & M's HGWA build - Finally a PCI date!!!!!!!! 302Jul 13, 2016 10:57 pm spuddles76 We had a look at the basins displayed on the southport, and at Prestart we were quoted $1500 each!!! Wow Spuddles that's crazy! jpmontoya Congrats on PCI date pinkjam Thanks Jpmontoya Re: J & M's HGWA build - Finally a PCI date!!!!!!!! 303Jul 14, 2016 11:19 pm Holy crapoly well im glad i wasnt offered an upgrade cause i probably would have taken it Re: J & M's HGWA build - Finally a PCI date!!!!!!!! 304Jul 16, 2016 10:35 pm So PCI went better than I expected which is good we had our own building inspector which was well worth the money as even tho HG say they have their own independent inspector you don't get to see their report so leaves you wondering...... A few things fellow HGers can keep in mind when your PCI comes around. - a number of Tek screws (roof screws) have been over tightened and in doing so this has damaged the washer which is designed to keep water out of the structure. -where the sewer vent pipes pass through the roof sheets, a weathering apron has been used as flashing and the penetration has been sealed with an elastomeric sealer. It is the inspectors opinion that this method of installation used to prevent moisture ingress does not constitute an adequate flashing method as the sealant may eventually deteriorate due to environment conditions. -minor rust stains in gutters due to metal shavings or scraps, left on surfaces it can lead to reduced life of the materials. - minor over spread of cornice glue contaminating face bricks in alfresco. - Mortar residue apparent on fences in various locations. - Where the ceiling joist had been cut to accommodate the return air grill of the air con and no trimmers had been installed to support the ends of the ceiling joist. The air grill appeared to be resting partly on the ceiling lining. In the inspectors opinion the ceiling lining alone is not capable of supporting the weight of the air con grille and additional support measures should be installed as the added weight may eventually cause the ceiling lining to fail. - the kitchen exhaust fan had not been connected to the roof flues. - Some ceiling insulation has been displaced and not fully covering the ceiling lining. - Minor scratches on facia and gutters near alfresco. We also picked up - painting touch ups here and there that need addressing - A laminate drawer is gouged and needs replacing - plastering around a PowerPoint where there is a massive gap needs repairing still although we were told it had been! - A tile with an awful rounded corner cut needs replacing. - alfresco sliding door needs adjusting - Laundry tap/pipe is leaking into the wall and soaked the wall. - Tap outside that has already been repaired previous is dripping again. - A PowerPoint in the powder room had been moved to "comply" but had been put in a ridiculous spot so have asked for it to be moved. - Our star lights weren't working as the SS said the globes were faulty and needed replacing. Cleaning could of been better too, silicon needs removing off benches and glue on glazed doors which make the glass look all scratched, paint overspray on wardrobe railings but it seems when I commented that we will be cleaning it off our selves, we were told what cleaning product to buy to do it The ridiculous placement of the PowerPoint. Would they put them like this in their display homes I asked?! I don't bloody think so http://i40.photobucket.com/albums/e243/pinkjam1/7140FADC-335D-447D-877E-F6D666F3BD31_zpsnfeycppz.jpg Re: J & M's HGWA build - Finally a PCI date!!!!!!!! 305Jul 16, 2016 10:55 pm Thanks Pinkjam for the heads up. Re: J & M's HGWA build - KEYS TOMORROW!!!!! 306Jul 19, 2016 6:55 pm So we have finally been told we can pick up our keys tomorrow. I know we should be excited but actually I'm not.... It's been the most frustrating experience with HG and to make matters worse our pool was to be installed on Thursday which we had to cancel due to HG not committing to a key handover date. Now pool filter pipes won't be in place before our aggregate gets poured which I guess means moving the filter from its planned tucked away spot down the side of the house to somewhere in our already limited backyard! Things are still on the "to fix" list from PCI apparently but we will see tomorrow how big that list is..... I think HG should be giving us a case of Moët not just a bottle! On a better note our alfresco zero course grano gets poured tomorrow, tiles delivered Friday and the tiler starts Saturday Re: J & M's HGWA build - KEYS TOMORROW!!!!! 307Jul 19, 2016 8:18 pm Yay for keys. Hopefully the "to fix" list will be very small, or nonexistent. Re: J & M's HGWA build - KEYS TOMORROW!!!!! 309Jul 29, 2016 11:26 pm So lots has been happening and trying to co ordinate trades and giving them access while working full time and living an hour away is proving a challenge! There's only so many garage remotes to hand out Pool got installed today http://i40.photobucket.com/albums/e243/pinkjam1/9F9690CA-0C7E-4F95-9B35-9F02A2902F69_zps5oand4ib.jpg http://i40.photobucket.com/albums/e243/pinkjam1/2286D5AB-1559-44C7-B70B-9437DBC39F72_zpsfm43lk41.jpg http://i40.photobucket.com/albums/e243/pinkjam1/1D8176EC-4514-4273-B484-8932F01B3CED_zpsi2ecvm8s.jpg Got the alfresco area rendered, he has to complete the texture coat yet http://i40.photobucket.com/albums/e243/pinkjam1/041AB3EE-D163-4A56-B6C1-2A2D636A1A78_zps1lnmx7ow.jpg Tiling has started but not finished and now we will need to put back tiling the alfresco since a bloody massive temp fence got installed today and is going to be in the way of the aggregate pour on Monday and the renderer to finish Thursday http://i40.photobucket.com/albums/e243/pinkjam1/C07B209C-FB82-49F0-A57A-87DF0CF667F3_zpswqtzzsgq.jpg http://i40.photobucket.com/albums/e243/pinkjam1/91729942-1840-4616-8813-734FDDE25F45_zpsilqi9mvl.jpg Re: J & M's HGWA build - KEYS TOMORROW!!!!! 311Aug 04, 2016 9:34 pm So we still haven't been able to drop the front door lock so HG can have access to do fixes! So who knows who's coming and going in our home, even tho we asked to be informed who was accessing it they didn't and haven't had the courtesy to let us know. We have a leaking pipe in the laundry cavity wall that they couldn't find the leak but finally today think they've found it but it means our laundry cabinet needs pulling out and won't be reinstalled till next Tuesday tho I'm not holding my breath with the rubbish trades HG has because the leak was picked up at PCI and we were told it was fixed!!! What did the idiots fix then?! Oh yeah and our ensuite toilet rocks like a see saw when you sit on it and I can move it side to side! Why take your kids to the park when I have a see saw in my bathroom! AND we are owed $1000 for recessed tracks we didn't get because they were "missed in construction" after several emails we are yet to see the money even tho they requested our back details to make payment Quick update tho, driveway and sides of the house aggregate done. http://i40.photobucket.com/albums/e243/pinkjam1/8C70F0B7-4EC8-4E5A-9592-7065D2ADCADC_zps9kk8yhkr.jpg Re: J & M's HGWA build 312Aug 04, 2016 11:37 pm Aww that's terrible Pinkjam, hopefully it will all be sorted for you soon, so you can enjoy your beautiful new home. Can I ask what colour your front render is? It's gorgeous Follow our HGWA build in Baldivis @ https://forum.homeone.com.au/viewtopic.php?t=83352&f=31&p=1604334#p1604334 Re: J & M's HGWA build 313Aug 05, 2016 3:17 pm That's a is such a shame pinkjam!! I really home hgwa pickup there game. On another note, your frontage is beautiful!! Love the aggregate too Re: J & M's HGWA build 314Aug 05, 2016 9:49 pm dee13 Aww that's terrible Pinkjam, hopefully it will all be sorted for you soon, so you can enjoy your beautiful new home. Can I ask what colour your front render is? It's gorgeous Thanks Dee, the colour is dulux ghosting half strength MrsMaccaPacca That's a is such a shame pinkjam!! I really home hgwa pickup there game. On another note, your frontage is beautiful!! Love the aggregate too Thanks maccapacca we will get there eventually, I just want HG out of my life! Re: J & M's HGWA build 315Sep 05, 2016 12:08 am Hi Pinkjam, I've been checking out your build & absolutely love your selections. I'm also building with HGWA but haven't done pre-start yet. If you don't mind me asking, are your ensuite tiles from European Ceramics or Crosby & what are they called? Re: J & M's HGWA build 318Dec 31, 2016 12:12 pm Pinkjam So sorry Bella, I'm not receiving notifications so didn't realise you'd written. I'm assuming you've done Prestart now? Hi Pinkjam, I was reading through your thread and noticed you managed to get a zero coarse alfresco. We are also building with HGWA and they told us this wasn't possible. We want a zero coarse tiled alfresco. Did you do this through HGWA? Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 18839 Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the… 0 9004 |
