Browse Forums Building A New House Re: KDR with Sekisui - Sydney 221Apr 14, 2015 9:02 am Taking a leaf out of Deluded's thread, I thought it might be helpful for others in the future to be able get an idea as to the progress of works on our build and use that to approximate timings for themselves. Update: It is useful for about the first 6 months from March to September 2015. After that, things went well and truly awry - hopefully your build doesn't match mine in that respect! Key pre-construction dates 20/09/13: Tender process commenced 25/05/14: Contract signed 13/08/14: DA approved 02/10/14: Demolition completed Construction Dates 04/03/15 Fence installed, site scraped and leveled. 06/03/15 Port-a-loo dropped off and fence locked. No works on site for the next couple of days. Site Establishment: Working days: 5 On site days: 2 11/03/15 Piering holes dug and concreted. Majority of slab formwork installed. 12/03/15 Underslab plumbing installed. 13/03/15 Plastic put down, foam pods and reinforcing placed. 16/03/15 Detailed formwork done incl setdowns etc. 17/03/15 Engineer inspection and formwork levels survey. 20/03/15 Slab poured. Slab left alone for 4 calendar days. 25/03/15 External stormwater and sewer drainage installed. No works for a couple of days Slab and drainage: Working days: 12 On site days: 7 27/03/15 Delivery - frames 30/03/15 Ground floor framing and 1st floor joists installed 01/04/15 1st floor flooring installed 02/04/15 1st floor wall frames erected 11/04/15 Aluminium windows and doors installed 17/04/15 Roof trusses 90% completed. Framing done prior to bricklaying: Working days: 9 On site days: 4 Framing done during bricklaying: Working days: 1 On site days: 1 13/04/15 Delivery - bricks 14/04/15 Bricklaying commences - setup and 1st course 15/04/15 Bricks - 18 courses to half the house 16/04/15 Bricks - 18 courses completed all round. Base of front balcony piers placed 17/04/15 Bricks - 29 courses completed to theater and alfresco. Front porch 75%. Balcony piers 18 courses 24/04/15 Plumbing - Main stack and waste drains for bathrooms 24/04/15 Scaffolding - commenced 27/04/15 Bricks - completed 29 courses to all single level areas. 5 courses to upper level beside garage roof 27/04/15 Plumbing - Installed all tap points (not connected). Main line run from outside 27/04/15 Scaffolding - completed. Scaffolding erected: Working days: 2 On site days: 2 29/04/15 Framing - finished roof trusses to main roof and over balcony 29/04/15 Delivery - bricks and sand delivered late in the day 30/04/15 Bricks - fully enclosed front lounge and study on front and right 01/05/15 Bricks - stacked bricks to upper scaffolding and set up lines in between rain showers 05/05/15 Bricks - completed alfresco columns, 2/3 balcony and front facade up to upper level floor 06/05/15 Bricks - completed right side wall up to roof, approx 12 courses above upper floor to front and left side 07/05/15 Bricks - additional bricks delivered, left side wall completed, a couple of extra courses to balcony 08/05/15 Bricks - balcony completed, window sills completed, redoing single garage pier (half complete). Bricklaying: Working days: 17 On site days: 11 15/05/15 Delivery - gutters and fascia plates 19/05/15 Scaffolding - a couple of hours spent repositioning along the front facade 20/05/15 Roof - Gutters and fascia panels installed 25/05/15 Scaffolding - another couple of hours spent repositioning to front and left side 26/05/15 Delivery - roof tiles and battens 28/05/15 Delivery - eaves materials and a couple of cavity slider frames 01/06/15 Roof - upper roof installed including all hip and ridge caps 02/06/15 Cleaning - upper level external walls acid-washed 03/06/15 Framing - welder on site briefly to put two weld joints in to beams that didn't have bolt holes 05/06/15 Roof - Eaves installed to upper roof 10/06/15 Render - 1/3 of upper facade. Paint - first coat to upper eaves. Bricks - removed extra pillar from balcony 11/06/15 Render - 2/3 of upper facade. Plumbing - 3x downpipes to right side wall fully installed 12/06/15 Render - Upper facade complete 15/06/15 Delivery - gutters and fascia plates for lower roofs. Scaffolding - dismantle sides and rear (front remains). 16/06/15 Framing - garage roof completed, ready for tiling. 18/06/15 Roof - gutters and fascia panels installed to low roofs over garage and alfresco/office 19/06/15 Scaffolding - lower roof scaffolding installed 22/06/15 Scaffolding - upper roof barriers removed and infill roof tiles installed 23/06/15 Roof - lower roofs and ridge caps installed. Whirlybirds installed. Roofing incl Eaves: Working days: 26 On site days: 7 24/06/15 Cleaning - lower half of external walls acid-washed 26/06/15 Air Con - ductwork and ceiling units installed throughout 26/06/15 Cladding - installed to rear 26/06/15 Scaffolding - removed from low roofs 29/06/15 Framing - trimming battens installed for ceiling, floor plates cut out at doorways, cavity slider to cloak room 01/07/15 Plumbing - rough-in completed 02/07/15 Framing - fixing details for wall sheeting, eaves to lower roofs, additional support posts, bath framing 02/07/15 Plumbing - remainder of downpipes connected, fixed small leaks from previous day Plumbing (not incl fitoff): On site days: 4 02/07/15 Electrical - approx 2/3 rough-in complete throughout 03/07/15 Electrical - complete rough-in internally, install meter box 06/07/15 Render - right half of lower level. 06/07/15 Framing - balcony floor structure and ceiling battens above installed 07/07/15 Scaffolding - completely removed 07/07/15 Render - corners trimmed around windows above and below balcony 08/07/15 Delivery - Plasterboard 08/07/15 Insulation - installed throughout 08/07/15 Render - inside front porch 09/07/15 Plasterboard - installed (possibly a small amount left for the next day) 09/07/15 Render - small section adjacent front porch 10/07/15 Render - finished inside balcony and around upper windows 10/07/15 Electrical - chased through balcony and piers and ran cables Electrical (not incl fitoff): On site days: 3 14/07/15 Render - completed lower level Render (incl part days limited by other works): On site days: 8 15/07/15 Cleaning - rubbish removed from around the site 16/07/15 Plasterboard - sanding back all of the setting tape throughout 20/07/15 Plasterboard - cornices 3/4 installed 20/07/15 Carpentry - stair installed 20/07/15 Delivery - doors, jambs, architraves, skirting 21/07/15 Plasterboard - cornices completed Plasterboard: Working days: 10 On site days: 5 22/07/15 Carpentry - commence door jambs, skirtings, architraves, hanging doors 23/07/15 Carpentry - continue skirtings, architraves. Complete hanging internal doors 24/07/15 Carpentry - continue skirtings, acrhitraves. External doors hung 27/07/15 Tiling - Waterproofing of all wet areas. 31/07/15 Carpentry - a few more architraves Door frames, skirtings, architraves: On site days: 4 03/08/15 Electrical - new pole installed, mains cable run from pole to house 04/08/15 Electrical - Meter board installed (circuit breakers only, no meters yet) 04/08/15 Delivery - kitchen and bathroom cabinets 05/08/15 Carpentry - frames for kitchen servery installed, kitchen island made correct size 06/08/15 Cabinets - kitchen and bathroom cabinets installed 10/08/15 Plasterboard - shower niches fixed up, walls through stair completed, various patches 12/08/15 Tiling - waterproofing the shower niches recently fixed up 14/08/15 Electrical - mains connected to property pole, meter installed and cabling connected to back of meter 18/08/15 Cabinets - bathroom cabinets removed for tiling 19/08/15 Plumbing - fixed leak in bathroom, installed drain to balcony 20/08/15 Tiling - underfloor heating installed 21/08/15 Carpentry - Bulkheads to kitchen and hallway framed, skirting and architraves completed, front facade framed for cladding 24/08/15 Delivery - Tiles and grout 24/08/15 Tiling - cement bed laid in bathrooms and laundry 25/08/15 Carpentry - finished cladding to front facade 25/08/15 Tiling - moved all tiles inside the house 26/08/15 Tiling - floors to bathroom, laundry and 1/2 ensuite glued down 27/08/15 Tiling - finished floor to ensuite and powder room, 1/2 walls to bathroom, skirting around laundry, WIP splashback, bed to front porch 27/08/15 Plumbing - water tank delivered into place 28/08/15 Tiling - face of bath in bathroom incl special trim plus more wall tiles. Grout floors in all areas and fix bed around drains 29/08/15 Tiling - ensuite feature wall and half wall behind the shower, bathroom completed walls around bath and the bath top 01/09/15 Tiling - front porch completed, bathroom walls 80%, ensuite walls 75%, powder room walls 70% 02/09/15 Plumbing - connected water and drains to rainwater tank 02/09/15 Tiling - cornices removed in all three bathrooms, ensuite walls 95%, powder room walls 95% 03/09/15 Tiling - powder room walls complete, ensuite walls complete, bathroom walls 98% 04/09/15 Tiling - bath hobs completed, shower niches partially complete 14/09/15 Tiling - topping bed to balcony removed 17/09/15 Tiling - waterproofing prep coat on balcony 21/09/15 Tiling - waterproofing 1st coat on balcony 22/09/15 Tiling - waterproofing 2nd coat on balcony 25/09/15 Carpentry - first floor sanded throughout 06/10/15 Tiling - re-laid topping bed on balcony 07/10/15 Tiling - waterproofing 1st coat to bed on balcony 08/10/15 Tiling - waterproofing 2nd coat to bed on balcony 09/10/15 General - rubbish cleared from site 13/10/15 Carpentry - cut ceiling access hole in WIR, installed trims to stair wall joints 14/10/15 Carpentry - removed tiles and walls sheeting from east side of ensuite wall and straightened wall by forcing over and fixing from above 15/10/15 Roofing - skylight installed 21/10/15 Cabinetry - kitchen stone benchtops installed 21/10/15 Electrical - holes cut and ends pulled through ready for fitoff 26/10/15 Plasterboard - repairing patches, re-sheet ensuite wall, bulkheads to kitchen and entry corridor, sheeted inside of laundry chute 27/10/15 Plasterboard - re-installed cornices to bathroom, installed cornices to kitchen bulkheads, additional patching to walls and ceilings 04/11/15 Carpentry - replaced some window architraves, filled in brickwork holes around balcony. Also nailed ground floor skirtings in properly (supposed to just leave tacked on) 06/11/15 Painting - protection laid out, ceilings sprayed and rolled, inside wardrobes rolled. 06/11/15 Cabinetry - servery bench installed, laundry chute doors installed in bathrooms 10/11/15 Painting - patching architraves ready for painting 11/11/15 Painting - tidying up ceilings, rolled internal walls undercoat (except garage, laundry and linen corridor) 11/11/15 Delivery - timber and decking for alfresco 12/11/15 Painting - completed walls undercoat, two coats to alfresco ceiling, commenced cutting in throughout 13/11/15 Painting - continued with cutting in, patched stair ready for painting later 17/11/15 Carpentry - alfresco deck installed 18/11/15 Scaffolding - front facade erected for rectification works 24/11/15 Carpentry - removed cladding from front facade 25/11/15 Carpentry - removed tiles and wall cladding from west side of ensuite wall, straightened wall properly 30/11/15 Painting - hand painting in small areas 01/12/15 Painting - architraves and door jambs 02/12/15 Painting - polyfilla to upstairs skirtings 02/12/15 Garage Doors installed 03/12/15 Painting - started on internal doors 04/12/15 Painting - completed internal doors, sealed alfresco deck 08/12/15 Painting - general touch-ups, gloss coat to upper level architraves, second coat to internal doors 10/12/15 Plasterboard - re-sheet ensuite wall, repairs and patching throughout 10/12/15 Delivery - colourbond capping for balcony (incorrect colour) 14/12/15 Painting - sanding back architraves, gloss final coat to most upstairs door frames 15/12/15 Painting - first coat to to render on front facade and balcony 15/12/15 Delivery - colourbond capping for balcony (correct colour) 16/12/15 Delivery - most internal door hardware and bathroom towel rails etc 17/12/15 Roofing - colourbond capping installed 17/12/15 Carpentry - cut all door handle holes and recesses, installed some handles, removed extra column of wall tiles in ensuite 18/12/15 Carpentry - re-installed cladding to front facade 19/12/15 Carpentry - fitted more door handles, re-hung balcony door, general tidy up in garage 19/12/15 Painting - new external cladding 21/12/15 Painting - sanded patches from plasterboard repairs, started 2nd coat to internal walls 22/12/15 Painting - completed 2nd coat to internal walls, touch ups to underside of balcony, started on gloss to window frames 23/12/15 Painting - continued gloss to window frames 24/12/15 Painting - completed gloss to window frames and gloss coat to stair balustrade 08/01/16 Carpentry - removed extra row of floor tiles in ensuite 11/01/16 Carpentry - removed plasterboard around insufficient structure in garage 12/01/16 Tiling - waterproofing 1st coat to new ensuite wall 13/01/16 Tiling - waterproofing 2nd coat to new ensuite wall 13/01/16 Carpentry - removed cladding again from front facade 15/01/16 Painting - external doors painted and eaves around alfresco 16/01/16 Tiling - tidied up bathroom floors and brought new tiles into the house 18/01/16 Tiling - re-laid bed to floor around Ensuite wall 19/01/16 Tiling - laid entry tread to porch, floor to balcony, main bathroom walls 100%, wall in ensuite, all floor drains 19/01/16 Delivery - extra towel rails to replace incorrect ones 20/01/16 Tiling - laid skirting and entry tread to balcony, floor tiles to ensuite, niches and windows sills. Complete. Tiling (incl waterproofing and rectification works): On site days: 25 20/01/16 Painting - painted all downpipes (except one) Painting (not incl final tidy-up): On site days: 20 25/01/16 Delivery - toilets, baths, cladding for facade 27/01/16 Framing - new steel post welded in place at garage opening 28/01/16 Measure up for shower screens and splashback 01/02/16 Tiling - came to repair drains and other small issues, didn't have correct tiles to do the works 01/02/16 Roofing - new colourbond capping delivered 02/02/16 Tiling - pulled up non-level floor tiles, still didn't have correct replacement tiles 02/02/16 Roofing - colourbond capping installed except for one section (need extra piece manufactured) 03/02/16 Electrical - fitoff 50% completed 03/02/16 Delivery - more lead flashing plus sand to make bed for baths 04/02/16 Plumbing - fit-off baths, showers, taps, kitchen, laundry (all except w/c pans and bathroom cabinet taps) 05/02/16 Electrical - fit-off part of downstairs. 05/02/16 Carpenter - re-did cladding to front facade, straightened eaves over garage door. 06/02/16 Electrical - completed fit-off and connected to mains 06/02/16 Carpenter - installed 90% bathroom fixtures, external door seals, replacement door to under stair 08/02/16 Tiling - pulled up tiles from Ensuite floor 09/02/16 Electrical - tested with bulbs throughout, fixed up wiring and switching issues 09/02/16 Painting - new front facade, eaves over balcony, correct colour to front downpipes 10/02/16 Tiling - re-laid 80% of ensuite floor 10/02/16 Painting - second coat to facade cladding, fix up marks, external lintels, inside balcony second coat 12/02/16 Tiling - completed fixing drains in all bathrooms (still need to grout) 14/02/16 Tiling - grouted ensuite floor and new drains in other wet areas 15/02/16 Roofing - fitted final piece of colourbond capping to balcony 15/02/16 Fixtures - installed shelves and rails to WIP, WIR, 3x bed robes, cloak room and linen cupboard 17/02/16 Roofing - balcony handrail installed 18/02/16 Scaffolding - dismantled from around balcony (but still on site) 18/02/16 Screen - installed shower screens, mirrors and kitchen splashback 19/02/16 Plasterboard - replacement cornices, replacement panel in garage, patch defects throughout 23/02/16 Carpentry - installed external door weather seals, hung replacement doors 23/02/16 Plumbing - installed toilets to all bathrooms 24/02/16 Plumbing - installed taps to vanities and new lead flashing to roof 25/02/16 Electrical - installed oven, installed rangehood (but incorrect height), stove top was gas instead of electric 26/02/16 Driveway - excavation, 75% of reo and formwork installed 29/02/16 Cleaning - initial sweep and scrape of floors. Also rubbish removed from front of site by bobcat. 29/02/16 Painting - painted over patching, extra downpipe and the lead flashing to the roof 29/02/16 Termite protection installed around perimeter of house and around balcony column 29/02/16 Driveway - reo and formwork completed and grated drain positioned and connected 01/03/16 Cabinetry - installed laundry chute door and adjusted all other cabinet doors 01/03/16 Driveway - first half poured 02/03/16 Driveway - second half poured 02/03/16 Cleaning - more detailed to windows, bathrooms (also took panes out to clean tracks) 03/03/16 Tiling - fixing bumpy niche in powder room, silicone all internal corners throughout 03/03/16 Driveway - seal coat applied and saw cuts done 03/03/16 Authorities - Certification inspection done 04/03/16 Carpenter - patched render behind garage door, stair treads floor beside alfresco door 07/03/16 Fence removed 07/03/16 Painting - completed second external coat and some touch-ups internally 08/03/16 Painting - touch-ups everywhere after SS inspection 08/03/16 Insulation batts arranged in upper ceiling 08/03/16 Tiling - controllers for underfloor heating installed) 09/03/16 Delivery - correct cooktop (electric version) arrived 09/03/16 Final internal clean - not a great deal much more clean than before 10/03/16 HANDOVER . . . 18/02/16: Handover nominated for 10/03/16 Works remaining as at 09/03/16 - Install A/C fan coil unit and connect (booked in for handover morning) - Install fly screens (booked in for handover morning) - Install stove and fix height of rangehood (booked for Tue 15th Mar) - Fix light switching to garage, add external grill to rangehood exhaust and connect underfloor heating circuits to breakers (booked for Tue 15th Mar) - Fix garage door motorised operation - Fix broken external stormwater pipe, punch out through kerb and connect to driveway drain Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 222Apr 14, 2015 9:52 am deluded I'm sure the brickies will be complaining ... who in their right mind would put a pallet of bricks on top of another pallet? Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 223Apr 14, 2015 9:57 am deluded I know it is personal choice I would have opted for a flush with the render ... The render is all over the front face and returns down each side to the first downpipe. Brickwork then on the other side of each downpipe and round to the back. You might be right though - I'll let you know what I think when I see it in situ when it's all finished! Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 224Apr 14, 2015 10:15 am clintdb deluded I know it is personal choice I would have opted for a flush with the render ... The render is all over the front face and returns down each side to the first downpipe. Brickwork then on the other side of each downpipe and round to the back. You might be right though - I'll let you know what I think when I see it in situ when it's all finished! apologies mate ... i think it came across wrong .. .. was merely thinking about your comment on bricks chipping and showing a different color, so if you want it rendered or painted over flush would blend with your existing render (less prep work etc etc) .. noticed your timeline and slab curing time was only about 2 weeks. did you engage an independent inspector to check slab? Re: KDR with Sekisui - Sydney 225Apr 14, 2015 10:35 am No - you're fine Deluded. I knew you weren't being critical I take your point on painting the bricks, but it's unlikely we'll do that. If we do additional rendering down the track then I reckon the render will get into the joints. Of course, I could be completely wrong, but with the brickies already started, I'm putting this one into the "too late - we'll live with it" basket! With the slab, I did my own inspections on the reo and slab thicknesses. Also watched the pour to check for any issues with slump or the subbies adding too much water etc. They don't take individual cylinders away on every single job for destructive strength testing. The batch plants produce such consistent mixes these days that they only take a cylinder away every 30 or so house slabs, just to make sure it's all still ok. You get around 2/3 - 3/4 of the design strength of concrete in the first 7 days, so this is plenty for the purposes of putting up framework etc. My biggest concern was actually having the digger drive over it in order to dig out the drainage trenches at the back of the house, but it was 5 days later and the loads were spread over the caterpillar tracks, so it was all fine. Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 226Apr 14, 2015 11:03 am lost my response but I was saying that I can't believe how well timed your build is. In terms of scheduling. Kudos to your SS. *touching my head* Touch wood that I haven't jinxed you!! Re: KDR with Sekisui - Sydney 227Apr 14, 2015 12:05 pm Yeah, I was thinking that too Yvonne - not that your head is made of wood - the other thing, that I hope it continues to go this well! Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 228Apr 14, 2015 5:22 pm Not much to show today. Just one row of bricks right around the house. The brickies did get everything set up though. Moved the bricks around into readily accessible piles, located all the corners - all that sort of thing. And that first row is definitely the most time consuming. Let's see what tomorrow brings! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 229Apr 14, 2015 10:47 pm Thanks for pics of the floor joist. Will you be having insulation as well? Subfloor? Re: KDR with Sekisui - Sydney 230Apr 14, 2015 10:51 pm We haven't got anything specified at this stage. But are currently thinking of it. We are finding it much more efficient and cheaper to deal directly with subbies for any variations to the works that can be incorporated into their role, so I plan to wait until "insulation time" and see what we can arrange then. Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 231Apr 15, 2015 8:10 pm 18 courses of bricks around half the house today. All exceptionally straight and true. Great work so far from the brickies. Rear of the house around the theater (office) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looking from the front down the right hand side of the house Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 234Apr 15, 2015 11:11 pm Thanks guys - appreciate you saying so Personally, I'm still a little unsure if it's not going to look a bit stark and plain once it's all finished. It was certainly a bit more "glary'ish" in the afternoon sun today as compared to our neighbours' houses. But I don't think it's going to be terrible or anything - just second guessing myself as to whether something else could have been better. But as I said a couple of days ago when discussing the colour painted on to the face of the bricks (and I quote); "1) It's too late now" Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 235Apr 16, 2015 12:24 am it is certainly interesting the way they laid the bricks for that front right side. how would you place the bricks for the return and to ensure it interlocks properly if you leave it like that? I wonder if they would jam in the cement before sliding the brick in? Re: KDR with Sekisui - Sydney 236Apr 16, 2015 5:38 am clintdb Thanks guys - appreciate you saying so Personally, I'm still a little unsure if it's not going to look a bit stark and plain once it's all finished. It was certainly a bit more "glary'ish" in the afternoon sun today as compared to our neighbours' houses. But I don't think it's going to be terrible or anything - just second guessing myself as to whether something else could have been better. But as I said a couple of days ago when discussing the colour painted on to the face of the bricks (and I quote); "1) It's too late now" :: Ah the joys of the second guessing! Re: KDR with Sekisui - Sydney 237Apr 16, 2015 6:47 am deluded it is certainly interesting the way they laid the bricks for that front right side. how would you place the bricks for the return and to ensure it interlocks properly if you leave it like that? I wonder if they would jam in the cement before sliding the brick in? Seeing as it is being rendered around that corner, it probably won't matter so much if the bricks are not quite perfect looking, so perhaps that's why they can do it this way. Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 238Apr 16, 2015 8:45 pm I didn't get to watch them interlock the bricks into the corners, but it would appear that what we all though yesterday is what actually happened - that they just laid the mortar around and pushed them into place Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ All around the house is now up 18 courses. Corner guides have been adjusted upwards for the extra courses tomorrow (weather permitting). Front Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Left side (photo taken from the rear) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: KDR with Sekisui - Sydney 239Apr 16, 2015 8:55 pm Is there supposed to be a layer of insulation between floor and bricks, our old house has a metal lining visible around the garage 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: KDR with Sekisui - Sydney 240Apr 16, 2015 8:57 pm Maybe that was a termite barrier? These days, most places (including ours) get a liquid sprayed around which then has to be redone every few years to ensure the house is still protected. Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37143 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19107 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13444 |
