Browse Forums Building A New House Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Roo 41Dec 12, 2013 9:52 pm The quality is fine cause I can see the roof! Have they fixed the window and brick pillar ? Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Roo 42Jan 03, 2014 3:47 pm 2-cupcakes-pls The quality is fine cause I can see the roof! Have they fixed the window and brick pillar ? Hi 2-cupcakes-pls sorryI've taken so long to reply, I went away mid December and have been away from my computer since then, it was a nice to take a long break from emails, fb etc. But now i am back to work and back in the swing of things. It turns out that on the window frame it was only some protective plastic capping that was damaged which will be removed when the glass gets put in. But have not heard anything about the brick pillar, i wasn't really expecting anything done over the Xmas break. Although the electrician came in sometime between Xmas & New Year and did all the chasing and marking out in preparation for the electrical wiring to go in. ~~Lethe~~ My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Roo 43Jan 03, 2014 3:52 pm Some pics of the completed roof frame Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our Carport Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front Facade Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Roo 44Jan 03, 2014 4:25 pm Looking good Lethe! My Mum built one of these flute homes a few years ago in Butler, It's amazing how much house they can fit on such small blocks and they don't feel small at all once your inside! Good luck with it all! Done it once.. Lived in it a year.. Sold it.. Doing it again! Addicted to Building.. Building with Dale Alcock in Ashby, WA https://forum.homeone.com.au/viewtopic.php?f=31&t=66684 Re: Lethe's House - Baldivis, Homebuyers Center: Flute 45Jan 07, 2014 4:28 pm Had both the plumber and electrician working at my house yesterday and from what I can tell all the cabling and piping are in, including my outside taps at the back and front of the house My kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bring on the Colorbond My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Lethe's House - Baldivis, Homebuyers Center: Flute - Colorbo 46Jan 20, 2014 2:56 pm So excited last Friday my Colorbond was installed Here are some pics taken at sunset Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ From inside... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The carport (including graffiti ) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ~~Lethe~~ My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Roo 48Jan 21, 2014 9:47 am Hi Lethe! I have been away too (a break from the computer) good thing about the window! now the roof is now it will start looking like a home. your house is no longer alone, it has a friend next door I see Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Roo 49Jan 21, 2014 5:05 pm Thanks Nicci All the flute homes in my part of the street are going up rather quickly, there was even some brickwork done over Xmas!!! I am guessing that they will all be finished roughly around the same time. Which will be good when we move as it might feel a bit less like a construction zone My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Roo 50Jan 22, 2014 5:44 pm Just drove past my place and they are working on the internal render. Yay, yay, yay!!! My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Roo 51Jan 22, 2014 6:41 pm wow there's no stopping them in this hot weather Lethe's House - Baldivis, Homebuyers Center: Flute - Render 52Jan 29, 2014 2:45 pm Well after a bad week which culminated in me dropping and permanently breaking my laptop (which I use for work and can not afford to replace at the moment ) I went by my place last night and checked out the rendering to discover that they had finished the inside and had already started on the outside Internal Grey render (kitchen & hallway) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front started Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I did notice that two of my powerpoints (well the hole and wires) were completely rendered over, is this something that I should let my CLO know about? I know that the electrician will come and find it again but seriously a hole in the wall with wires poking out how can you miss it? My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Ren 53Jan 29, 2014 8:12 pm it happens all the time! (so I have read on the forum) Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Ren 55Jan 30, 2014 8:36 pm Hey, you're place is looking great! Tez Avalon at Baldivis Homebuyers Centre Ultimate St Marks Our home thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64428 Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Ren 56Feb 03, 2014 1:48 pm Thanks Tezzle everything seems to be going smoothly at the moment Just adding a couple more photo's from last Friday of our completed external render and the celings in place Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Now it's beginning to look like a room i could actually live in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ While it looked like the render was completed last week I did notice when I drove past that they were back today... I'll check it out tonight to see if my layman's eyes can see anything new. My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Ren 57Feb 10, 2014 12:58 am Hi Renette I'm sorry that your build seems to be taking so long, it muzt be so frustrating For us the brickies were there most days until they were completed there may have been a few days here and there where nothing happened but it all went up pretty quickly. Our house is one of 8 HBC flute houses in a row (mine being the first to be started) and so there are people on site constantly and some of the trades will go between the different houses doing bits and pieces. Good luck on your build My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, Homebuyers Center: Flute - Ren 58Feb 10, 2014 1:47 am The plasterers started on Friday Kitchen / Dining Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lounge Room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hallway Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Loving my white walls it opens the place up again My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, HBC: Plastering Completed 59Feb 18, 2014 2:53 pm Yay the plaster / white set was finished last Friday Living area Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sisters Room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Although I do have one concern, we have patches of yellow in places should i be worried about this? I know that we will paint over it eventually You can see the yellow in this pic, now in this room it will be inside the BIR but there are other places (like around our front door) where it will be more obvious especially if we don't get to painting right away. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Also I have another rather silly question but are we still meant to be able to see the metal strip on the corners at this stage? Will they be visible until we paint the walls? My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Lethe's House - Baldivis, HBC: Plastering Completed 60Feb 18, 2014 3:10 pm Yes you are meant to see the strip it help protect the walls from chips. Once the paint is on you will not see it. THey are called corner beads I havent, and i havent looked to much into it, but on face value its not the saviour its trying to make out to be. Shared equity in your home is never a good idea. The… 1 4026 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6471 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39985 |
