Browse Forums Building A New House 1 Jan 06, 2012 5:15 pm While it seems common sense to think a slate roof would be BAL40 compliant, my surveyor seems unsure as it's not in the regulations. Does anyone have any info on slate roof compliance, in particular the ember catchment issue? Thanks in advance! My storybook home build: https://forum.homeone.com.au/viewtopic.php?f=38&t=57987 I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 4177 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 1123 just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue… 1 887 |
