Browse Forums Building A New House 1 Feb 04, 2011 3:20 pm We are about the start our build but we are getting the builder to just do the basic lights and getting a friend to do the electrical fitout - should there be 1 d/light for each sq m or for every 1.5sq m. Thanks Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: how far apart should downlights be? 2Feb 05, 2011 9:34 am nobody knows ??? Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: how far apart should downlights be? 3Feb 05, 2011 9:41 am I am far from an expert on this- and there is probably someone who has a better idea than I do but my understanding was that they will light up an area of approximately 1.5m....That may depend on the type of downlight I guess- I'm not really sure. Our electricians chatted with me about what I was looking for but they sorted out the exact placement. I think the measurements were about 1.5m but it depended on where the beams were etc. Have you done a search on H1?- I am sure there are probably countless threads on downlights and you'll probably find the answer in one of those threads Re: how far apart should downlights be? 4Feb 05, 2011 10:28 am Thanks miss Never thought to do a search (will do that now) Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: how far apart should downlights be? 5Feb 05, 2011 12:29 pm The rule of thumb I used (from memory ) was 1m from the wall and 2m between downlights. It does vary depending upon the room shape but it has worked really well. We have white walls, ceiling and darkish floors. The amount of light is great. Also, put some thought into how you want your downlights banked (ie how many turn on per switch). You can save a lot in lighting costs by only having the lights on that you really need. (ie. if you have a big room with 8, have 2 lots of 4 or 4 lots of 2). Re: how far apart should downlights be? 6Feb 05, 2011 5:08 pm Sierra The rule of thumb I used (from memory ) was 1m from the wall and 2m between downlights. It does vary depending upon the room shape but it has worked really well. We have white walls, ceiling and darkish floors. The amount of light is great. Also, put some thought into how you want your downlights banked (ie how many turn on per switch). You can save a lot in lighting costs by only having the lights on that you really need. (ie. if you have a big room with 8, have 2 lots of 4 or 4 lots of 2). Thanks so much - great tip too Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO The OP has gone The latch and striker are definitely not aligned but there was no point trying to help the OP understand that. Hence the reason they are no longer with us. 12 5678 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 15997 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20902 |
