Browse Forums Building A New House I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20648 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 4014 We are about to partially demo our house to begin a major renovation… by partial it almost may as well be a new build (keeping front for heritage) This will require the… 0 4986 |
