Browse Forums Building A New House Re: How often do you visit your site? 41Nov 09, 2010 9:03 pm Almost everyday But I have an excuse lol its 7 acres and we take the dogs out there for there daily run. Couldnt take them today was worried they would run all over the new slab So may have to spend twice as much time there tomorrow Cheers Janet Re: How often do you visit your site? 42Nov 10, 2010 8:32 am sleven Visited my site at 6pm tonight then went down with DH and Mum at 7.15pm - in that time someone tried to break in through the internal access door... AGAIN... GGGrrrrr I can relate to that...went to our site one night after work, timber windows in, all good. The next night, one timber window missing, ripped right out of the wall. No wonder we all go down to our site to check it out. I know we are insured by the builder but even so, you just don't want things stolen from your house! Plus depending on what they take there can be long delays in getting them replaced. We have just had our plastering done, mind you the 1st level bricking isn't finished yet. We are keeping as close an eye as possible on the place, but if they really want to take something they will. Builders say they can't do much about it. They actually factor in a percentage for losses in our contract price. Re: How often do you visit your site? 43Nov 10, 2010 2:42 pm It's really important to visit your site at the early stages, and take a tape measure with you! When things go seriously wrong in building its generally because mistakes are made with the set-out of the home and the construction of the walls. I'd suggest the following; 1. Plumbing Prelay - before the slab goes down. Check all plumbing points to make sure waste pipes are in the right position and not in walls and also check that all points are in! Often plumbers leave out a waste pipe for a vanity basin or a floor waste. Mistakes can be made after all, they are only human. 2. Once the slab is poured - Measure the slab distance from the boundary to ensure your setbacks are OK 3. As the walls are going up - Check your brickwork as it's going up to ensure the room dimensions are as per the plans. Good brickies will ping the slab which will show the setout of the walls. That's a great time to run your tape measure BEFORE they lay any bricks. Steve Fitzpatrick Re: How often do you visit your site? 44Nov 11, 2010 7:17 am I go at least once, if not twice a day, as it is on the way to and from Daycare drop off. Builder, from the start, has encouraged my prescence on site. I am also to do some work on my build too, which automatically allows me supervised site access. Cheers Building NBG Buckingham 320E Eastern Suburbs Melbourne Knockdown & rebuild Build startup 28th October 2010 http://buckingham320e-the4ofus.blogspot.com/ Re: How often do you visit your site? 45Nov 11, 2010 9:27 am YBBroker It's really important to visit your site at the early stages, and take a tape measure with you! When things go seriously wrong in building its generally because mistakes are made with the set-out of the home and the construction of the walls. I'd suggest the following; 1. Plumbing Prelay - before the slab goes down. Check all plumbing points to make sure waste pipes are in the right position and not in walls and also check that all points are in! Often plumbers leave out a waste pipe for a vanity basin or a floor waste. Mistakes can be made after all, they are only human. 2. Once the slab is poured - Measure the slab distance from the boundary to ensure your setbacks are OK 3. As the walls are going up - Check your brickwork as it's going up to ensure the room dimensions are as per the plans. Good brickies will ping the slab which will show the setout of the walls. That's a great time to run your tape measure BEFORE they lay any bricks. Steve Fitzpatrick Great tips - thanks Steve! Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: How often do you visit your site? 46Nov 11, 2010 9:43 am Yep we live in our shed at the back of the block so we are there 24/7. We lock up the gates at night and make sure that we open up again by 5.30am next morning as sometimes the tradies are there by then. Re: How often do you visit your site? 47Nov 13, 2010 1:29 am We generally go every night together. Sometimes during the day instead depending on work times for us. My friend lives 5 mins away and drives past then txts if anything is happening. There is more work happening around us now so we may meet some neighbours visiting their land, slab, and we met the people almost ready to move in. We thought we were strange getting so excitted to stand on our land, touch the slab, see workers on our site, then we found H1 and its all normal. Re: How often do you visit your site? 48Nov 13, 2010 10:28 am Nearly every second day I go visit my site. I mostly go after work since its just 10mins from work and pretty much the same distance from new home to current home... I've hardly seen any tradies working on the house. Its pretty amazing sometimes what they manage to do in a couple of days and what they dont do in weeks! Re: How often do you visit your site? 50Nov 13, 2010 8:44 pm When it was just a vacant lot I was visiting about once a month. Since we got the site start letter I've started visiting weekly but that'll increase once the slab is laid. We live about 15 to 20 minutes drive away, so far my wife has been there just the twice but we have a new born and she is waiting for the all clear to drive. Building the Ascent 3000 with Burbank http://www.burbank.com.au/HouseDetails.aspx?houseId=82 viewtopic.php?f=31&t=39638 Re: How often do you visit your site? 51Nov 16, 2010 10:48 am We are renting a couple of blocks away. Go past the build a couple of times a day on the way to shops etc. Get to see lots of Tradies and keep a close eye on progress. Re: How often do you visit your site? 52Nov 17, 2010 8:50 pm We're like you dove... today I went 4 times and we aren't even CLOSE to starting building yet.... I just like seeing the now vaccant block! ;o) Amazing_Venice [size=50]Signed: 31/07/10 Colour Appointment: 08/09/10 Deposit Tender 20 / 09 / 2010 Final Contract Signed 18 / 11 / 2010 Slab laid 02 / 2 / 2011 Frame completed 25 / 02 / 2011 viewtopic.php?f=31&t=37417&p=553032&hilit=oxford#p553032 Re: How often do you visit your site? 53Nov 18, 2010 9:12 am It gets worse AV. The more they build the more you have to look. THEN if it stops DESPAIR sets in. Until they start again. Re: How often do you visit your site? 54Nov 18, 2010 11:43 am I have no doubt it will get worse! I am a tad OCD... Amazing_Venice [size=50]Signed: 31/07/10 Colour Appointment: 08/09/10 Deposit Tender 20 / 09 / 2010 Final Contract Signed 18 / 11 / 2010 Slab laid 02 / 2 / 2011 Frame completed 25 / 02 / 2011 viewtopic.php?f=31&t=37417&p=553032&hilit=oxford#p553032 Re: How often do you visit your site? 55Nov 18, 2010 12:56 pm I go once a week and we have even signed out build contract yet! We do own the land though Re: How often do you visit your site? 56Nov 18, 2010 11:07 pm Our land is vacant ATM so i only drive past once every 2-3 weeks to keep my motivation going. Can't wait until they start building! Building the Porter Davis Sandhurst 33 Our Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=42820&start=20 Re: How often do you visit your site? 58Nov 20, 2010 10:59 am amazing_venice We're like you dove... today I went 4 times and we aren't even CLOSE to starting building yet.... I just like seeing the now vaccant block! ;o) Haha wow...I THINK WE HAVE A WINNER! Don't feel so bad going twice in one day and we are nearly finished! Re: How often do you visit your site? 59Nov 20, 2010 1:48 pm we lived on site why they were building up the back of 5 acres.we had to sign agrrement with the build we would not go near the build finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: How often do you visit your site? 60Nov 20, 2010 6:46 pm yvette72 we lived on site why they were building up the back of 5 acres.we had to sign agrrement with the build we would not go near the build So you didn't go and have a bit of a look after hours? 9 25308 In Victoria you cannot put a caveat on arising from a domestic building contract. 65 112912 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40827 |
