Hi Everyone,
Has anyone build a fence/wall using bricks? if you did. how much did it cost you per metre say for a wall/fence that is around 1.8m high.
MadCow
Browse Forums Building A New House Re: Cost of brick wall/fence ? 2Mar 25, 2010 8:58 pm I'm looking to do this as well on my corner block. cost will depend on how long the wall is and how many bricsk you need. You looking and brick pillar with infill, pillar and low wall with infill, full face brick, any render??? These help determine the type and therefore cost of brick per pallet. The brick I'm looking at is 300 brick per pallet @ $240ish a pallet and need approx 13 pallets (like I said cornor block abour 30m of fence + smaller 5/6 course wall round front of house) This cost does not include laying, morter, cement for footings etc. I'm still working on full costing (not sure if go pillars with 5/6 course wall and colourbond infill or full brick with render instead of colourbond) Decide what you want and visit you rlocal brick display for latest costing. If anyone else has any ideas on cost it would be appreciated. Also any opinions on full brick and render or colourbond?? You may also need council approval. Building "DOMAYNE" through COMMODORE HOMES in Pearsall WA Slab down 15-01-2010 Handover 16-06-2010 viewtopic.php?f=31&t=29049 Re: Cost of brick wall/fence ? 4Mar 31, 2010 8:28 am Hey MadCow - the other option would be these guys: http://www.modularwalls.com.au/gardenwalls.shtml I've seen the product up close - kicked a soccer ball into in, no damage - a lot cheaper than full brick walls to put up and quicker. I think it works out to about $200/m installed - but I believe that's cheaper than brick (unless you know a brickie or can DIY) After 4 years - we're in! Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 8593 4 11832 2 8388 |
