Browse Forums Building A New House 1 Jul 20, 2007 12:44 pm Our block is 19 x 39m and has an easment running 3m accross to the rear of the block. How deep is at normally run at and what exactly is the function of an easement "is it sewarage related"?
My intention is to plant several smalltrees in the two back corners and to place a few garden beds straight over the top Are there any regulations that prevent this, understandably i have been told you cannot put a slab and garden shed up over the top Milt, Re: Easements question 2Jul 20, 2007 12:58 pm Milt,
Go nuts! You can build a garden shed with a concrete base over the easement as well if you like! In the very unlikely event that the council need to dig up the pipe/s in your easement then they will dig it up. If you are in a new suburb I wouldn't worry about it in your lifetime Same goes for garden beds and trees!! Re: Easements question 3Jul 20, 2007 1:02 pm There are different types of easements.
This little PDF has a good explanation. http://www.gleneira.vic.gov.au/Files/BOE_Information_Pack.pdf With regard to planting, most councils advise to keep easements clear of trees. I suppose it depends on the council, the type of easement and the size of the trees you intend to plant. I would consult council regarding this issue as each council has their own policies. Small trees or shrubs however are rarely a problem. I'd just go ahead and plant those. I did at my last property. Re: Easements question 4Jul 20, 2007 1:16 pm Cookiemonster There are different types of easements. This little PDF has a good explanation. http://www.gleneira.vic.gov.au/Files/BOE_Information_Pack.pdf With regard to planting, most councils advise to keep easements clear of trees. I suppose it depends on the council, the type of easement and the size of the trees you intend to plant. I would consult council regarding this issue as each council has their own policies. Small trees or shrubs however are rarely a problem. I'd just go ahead and plant those. I did at my last property. Taken from the above publication: This is a good guide for anyone building in Melbourne.... Re: Easements question 5Jul 20, 2007 1:40 pm milt How deep is at normally run at and what exactly is the function of an easement "is it sewarage related"? Milt, Have a look at the land title/plan of sub...will say exactly what the easement is for. The easement will be numbered ie- E1 on the plan, then the front page wil say who the easment "belongs" to. Built Porter Davis "Dromana" 2007. Re: Easements question 6Jul 20, 2007 4:57 pm Thanks Mark for the information. Another good article to add to my blog!
Cheers Allan http://building-our-first-house.blogspot.com/ Current stage: Peg-out done, tiger tails installed, waiting for excavation to start... Re: Easements question 7Jul 20, 2007 6:21 pm Wooohoooo! I made the blog!
Im gonna get a t-shirt printed up. Re: Easements question 9Jul 20, 2007 7:32 pm Lost Dog Gday Allan. Which way did you go to get the Tiger Tails installed? Col Sorry, can you please rephrase the question again, don't think I understand your question.... Cheers Allan http://building-our-first-house.blogspot.com/ Current stage: Peg-out done, tiger tails installed, waiting for excavation to start... Re: Easements question 10Jul 20, 2007 7:43 pm Cookiemonster Wooohoooo! I made the blog! Im gonna get a t-shirt printed up. One T-shirt for you Mark! Cheers Allan http://building-our-first-house.blogspot.com/ Current stage: Peg-out done, tiger tails installed, waiting for excavation to start... Re: Easements question 11Jul 20, 2007 7:53 pm LOL!
Actually i was thinking more like "I MADE IT ONTO ALLAN'S BLOG AND ALL I GOT WAS THIS LOUSY T-SHIRT" Oh, and I changed my sig. Re: Easements question 14Jul 20, 2007 8:20 pm That's a nice picture!
Guys, guys, back to the topic, please... Cheers Allan http://building-our-first-house.blogspot.com/ Current stage: Peg-out done, tiger tails installed, waiting for excavation to start... Re: Easements question 16Jul 20, 2007 9:04 pm ahuang That's a nice picture! Guys, guys, back to the topic, please... There's a topic? Re: Easements question 17Jul 22, 2007 2:12 pm What I did at one of my house was to build a lawn locker put down a concrete slab that when across the easement but the garden shed did go over the easement so only the slab would need to be moved i used that area to store outside items like ladders etc.another way would be pavers.But no problems with trees or gardens make sure the roots are not to big
yvette You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10476 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6480 1 13417 |
