May 26, 2013 6:19 pmSign In47 members logged in
Triangular block
New Topic Post Reply  Page 1 of 1
 [ 5 posts ]
monkeyupatree
 Post subject: Triangular block
PostPosted: Jul 01, 2007 5:04 pm
We have seen a triangular block for sale and was wondering what are the disadvantages(advantages?) of them. The front is wide, it is on a bend in the road and tapers towards the back. Sorry can't give you the exact measurements......The whole block size is 600sqm.
At the moment we have 2 places in mind... one is the triangular shaped one and the other is a corner block- rectangular shaped, right beside a roundabout, (disadvantages/advantages about that one would be welcome too!). Having never purchased vacant land before I dont want to rush in, then regret it later so some advice would be welcome. :)
First_Timer_Ray
 Post subject:
PostPosted: Jul 01, 2007 5:11 pm
We have a triangular shaped block that is located at the base of a court (dead end court).
The plan that we have that fits really well is the Met...con Aspen 25, but we have one straight side, it's just that the other side tapers from the front to a point at the back, and the triangular shape of the house fits really well. There were a few other plans we found that could have suited a triangle shape (simonds, PD, etc) but we had the driveway crossover on the straight side, and didn't want to change it unless we had to (other plans had the garage on the other side).
My suggestion would be to weigh up which position you prefer. Check that you can get a few plans to fit and take a leap of faith that you are doing the right thing!
~Ray.
Yak_Chat
 Post subject:
PostPosted: Jul 01, 2007 5:55 pm
A friend has just split a trapezoid block and got 2 x long tepering blocks out of it - Not tirangle but fairly tapering, and the biggest issue she had was having to keep away from the boundaries.
The council wanted a 10 metre setback not 9 - this then pushed the house backward on the block - then the side of the house got to close to the side fence, so she had to change it and pull it in a bit, then the hallway was too small etc etc.
So I'd suggest you get your councils guidelines - ie seback front and side clearance etc - then work out your useable space, then look at what can fit on there.
It can be done - but just needs some lateral thinking on your part to work through the how can I fit this here?
Steve
Bud977
 Post subject:
PostPosted: Jul 01, 2007 8:41 pm
Bronze Member
Bronze Member
Yep, triangular blocks with the wide part at the front waste a lot of valuable space. You will end up with a big front yard and small back yard.
At least you get a lot of parking spaces out the front and in your yard.
The best type of triangular block lays at the end of a cul-de-sac. Small at the front, large at the rear. It ends up with the biggest back yard possible.
ahuang
 Post subject:
PostPosted: Jul 01, 2007 9:24 pm
Heard that the "Fung Shuai" for triangular lands might not be that good??!!
For the one next to roundabout, if the road is not wide enough and got busy traffic, it could be quite noisy... Personally would prefer a quiet street.
Cheers
Allan
http://building-our-first-house.blogspot.com/
Current stage: old house demolished, contract signed, waiting for excavation to start...
 [ 5 posts ]
Users browsing this forum: baferreri, BellaButterfly, christophert, dani_lori, daveinthehills, Davelle, Google Adsense [Bot], Google Feedfetcher, meowsy, patey, pennykate, pooks83, ScottB_33, shireduplex, Team PD, VandM and 83 guests
Read Article: Interior Design Gets Set for Winter by Dale Alcock Homes WAInterior Design Gets Set for Winter
As the winter chill sets in, we thought now would be…
Read Article: Cushions are an easy way of brightening up your home by Next Residential WACushions are an easy way of brightening up your home
Brilliantly bold cushions are the easiest and cheapest way to add…
Read Article: Great product - Enduroshield by Next Residential WAGreat product - Enduroshield
EnduroShield is an easy clean protective coating that creates an ultra-long…
Watch Video: The Archipelago II by Dale Alcock Homes WAThe Archipelago II
The sequel of our most popular home design, the Archipelago. For…
Watch Video: Classic Quarters Group Client Testimonial - Cam by Classic Quarters NSWClassic Quarters Group Client Testimonial - Cam
Hear from Cam about his experience building with Classic Quarters Group,…
