Browse Forums Building A New House 1 Feb 10, 2009 7:25 pm Hi All
Well, we have decided to ditch Wincrest and if we have to, forgo our deposit. It turns out that our DA (which had been in council since end of Nov) didn't comply anyway! Who knows what Wincrest were doing! So we are meeting with Council tomorrow and plan to pull the DA (or get it rejected - whichever is most cost effective). We will then take our custom designed plans and substantially change them so to avoid copyright problems. So the next stage is architect or draftsman? Wincrest did the soil tests and contour surveys etc so i intend to get those documents out of them so they can be used again. Also, since we have been burnt by the volume builder experience we are going to go with a private builder. Any thoughts on how long it might take/cost for an architect/draftsman to amend the plans and what should the process be with a private builder ie, fax them the plans, get a tender etc? What should we look out for? What questions do we need to ask? Thank you!! L Re: Private Builders 2Feb 10, 2009 7:34 pm IMO I think you should fax your original plans to a few builders and get some quotes.
If Wincrest folds there will be nobody to sue you. If they survive I am sure you can negotiate an outcome - it should be very easy. I know it sounds risky - but I think there are no risks and it makes sense... Anyway, that's me.. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Private Builders 3Feb 10, 2009 7:35 pm Hey Loretta
Happy to hear you've made a decision as to what you are going to do. I would think that since you have some detailed plans - that you are obviously happy with since you designed them - that you would only need a draftsperson to redo them with the compliant changes and any other changes necessary. In regards to an actual builder I'm not sure but I hope you can find someone and make progress. Good luck. Re: Private Builders 4Feb 10, 2009 7:40 pm Hi Loretta, this is not good news for you, having to move on after deposit and probably losing it, however, it could have been worse. As for your plans, perhaps have a chat with someone at Wincrest about moving on and see what they say about you using your original plans. It might lead to a good outcome for you.
Best of luck Annie A thankful person is a happy person. [/color]My hobby design blog: http://aviewondesign.blogspot.com/ Re: Private Builders 5Feb 10, 2009 7:42 pm Annietom Hi Loretta, this is not good news for you, having to move on after deposit and probably losing it, however, it could have been worse. As for your plans, perhaps have a chat with someone at Wincrest about moving on and see what they say about you using your original plans. It might lead to a good outcome for you. Best of luck Annie It's out of Wincrest's hands, unless you can backdate a deal... "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Private Builders 6Feb 10, 2009 8:20 pm Why not rally all those who paid deposits and approach the administrator. You will drop claims for your deposits if he will give you the rights to one house each?
Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Private Builders 7Feb 10, 2009 8:49 pm Ed, that is a very good idea. It might just work. I take your point about no one being around to sue. I will see what council says - we may well have to modify anyway but i would like to keep it as close as possible since i am pretty happy with it as is.
thanks for your advice. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12653 If you already have a contract, is the inspection cost stated in there? If not they would be forced to issue you a variation which you could of course object to. 12 26322 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12714 |
