Browse Forums Building A New House Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 52649 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61941 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 9092 ![]() |
