Browse Forums Building A New House Re: Cement Off 2May 10, 2024 5:22 am SGT Has anyone used a product called Cement Off to remove mortar and possibly render off black aluminium window frames & the rubber weather strip? Does it work? Thanks We use the bunnings verision and another product regularly at the end of a job, especially where you get concrete spashed on say powder coated gates and they work well in combination with a soft cloth. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Cement Off 3May 10, 2024 8:10 am Ashington Homes SGT Has anyone used a product called Cement Off to remove mortar and possibly render off black aluminium window frames & the rubber weather strip? Does it work? Thanks We use the bunnings verision and another product regularly at the end of a job, especially where you get concrete spashed on say powder coated gates and they work well in combination with a soft cloth. Thanks for that. I think the mortar has been sitting on these surfaces for approx a year. We’re at handover & they tried to get it off the rubber but have damaged it (gouged bits out) & scratched a bit of the frame 😟 Re: Cement Off 4May 10, 2024 8:12 am Ashington Homes SGT Has anyone used a product called Cement Off to remove mortar and possibly render off black aluminium window frames & the rubber weather strip? Does it work? Thanks We use the bunnings verision and another product regularly at the end of a job, especially where you get concrete spashed on say powder coated gates and they work well in combination with a soft cloth. Thanks for that. I think the mortar has been sitting on these surfaces for approx a year. We’re at handover & they tried to get it off the rubber but have damaged it (gouged bits out) & scratched a bit of the frame 😟 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4862 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3784 1 3461 |
