Browse Forums Building A New House 1 May 06, 2024 6:16 pm Re: Which 90cm rangehood is better 2May 07, 2024 2:18 pm Canopy and Undermount are best, and need to be ducted externally. Which one you go with will be largely determined by your design and joinery choices. What you should be paying attention to specifically is the extraction rate of the rangehood. We installed an undermount Euromaid that is the most powerful in class with an extraction rate of 1000m3/h and we love it. It is a little noisy, but that's to be expected of a unit with such strong extraction. https://www.euromaid.com/en-au/cooking/ ... ***#ucg90w If you want a quieter unit but not compromise on the extraction power, then you'd be looking for a unit that has an in line motor, where the motor is separate to the hood and installed in the ceiling cavity. These are amazing and you hardly even notice that they're on. But of course you can expect to pay more for them. https://www.winnings.com.au/p/whispair- ... -x3m08s5ip brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7942 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 3000 4 2150 |
