Browse Forums Building A New House Re: Which kickboard is better for kitchen & pantry 2May 05, 2024 1:23 am Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Which kickboard is better for kitchen & pantry 4May 06, 2024 9:13 am The stainless or aluminium are both just veneers of the product stuck on moisture resistant particle board. It's not solid material, so it's no different to a melamine or similar. What is more important is that the kickboards are sealed to the floor to prevent moisture and dirt getting in under the kickboards. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Which kickboard is better for kitchen & pantry 5May 06, 2024 1:09 pm chippy The stainless or aluminium are both just veneers of the product stuck on moisture resistant particle board. It's not solid material, so it's no different to a melamine or similar. What is more important is that the kickboards are sealed to the floor to prevent moisture and dirt getting in under the kickboards. great point. you are a champion Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 2860 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7839 Canopy and Undermount are best, and need to be ducted externally. Which one you go with will be largely determined by your design and joinery choices. What you should be… 1 1395 |
