Browse Forums Building A New House 1 May 02, 2024 12:16 pm G'day guys, During the PCI, we noticed that our Alfresco with feature rake ceiling had horrible quality. The sheets were all undulating, pretty much all nails were popping and the negative detail trimmers were all twisted and snapped at locations. The picture attached below is after they've patched it up and it's not even the worst location. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After many back and forth, builder admitted that they are rectifying a lot of their builds with this issue. They also admitted that it is not up to quality. They suggested to build new ceiling - However they are insistent on building it over the defective one, without taking them down first. We spoke to few ceiling fixers and they seem to be in line that to fix it properly, that the old defective one should be taken down first otherwise it'll cause issues down the track. Is this suggested solution by builder acceptable - Would you accept it? Re: Builder wants to build new ceiling over defective ceilin 2May 02, 2024 4:48 pm The builder's idea to put a new ceiling over the bad one without fixing it first might seem like a quick fix, but it's not the best solution. It's like covering up a problem instead of fixing it. It's important to make sure things are done properly to avoid more problems later on. I'd suggest talking to the builder about fixing the existing ceiling properly before adding a new one. Discover captivating worlds through my blogs. Just click here. Re: Builder wants to build new ceiling over defective ceilin 3May 02, 2024 6:19 pm H A W U G'day guys, During the PCI, we noticed that our Alfresco with feature rake ceiling had horrible quality. The sheets were all undulating, pretty much all nails were popping and the negative detail trimmers were all twisted and snapped at locations. The picture attached below is after they've patched it up and it's not even the worst location. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After many back and forth, builder admitted that they are rectifying a lot of their builds with this issue. They also admitted that it is not up to quality. They suggested to build new ceiling - However they are insistent on building it over the defective one, without taking them down first. We spoke to few ceiling fixers and they seem to be in line that to fix it properly, that the old defective one should be taken down first otherwise it'll cause issues down the track. Is this suggested solution by builder acceptable - Would you accept it? What is that product they have used? Also, do they know what is causing it and why won't they take down the current sheets? Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Builder wants to build new ceiling over defective ceilin 4May 06, 2024 1:18 pm Ashington Homes H A W U G'day guys, During the PCI, we noticed that our Alfresco with feature rake ceiling had horrible quality. The sheets were all undulating, pretty much all nails were popping and the negative detail trimmers were all twisted and snapped at locations. The picture attached below is after they've patched it up and it's not even the worst location. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After many back and forth, builder admitted that they are rectifying a lot of their builds with this issue. They also admitted that it is not up to quality. They suggested to build new ceiling - However they are insistent on building it over the defective one, without taking them down first. We spoke to few ceiling fixers and they seem to be in line that to fix it properly, that the old defective one should be taken down first otherwise it'll cause issues down the track. Is this suggested solution by builder acceptable - Would you accept it? What is that product they have used? Also, do they know what is causing it and why won't they take down the current sheets? G'day @Ashington Homes, thanks for your reply. The material is Versilux Ceiling Lining and Trimmer is negative detail trimmer. In their words, 'Inferior level of finish is achieved on site caused by construction constraints of this product'. However, I've been on site everyday and they have proceeded to use trimmers (brackets between the sheets) which have significantly twisted, bent and snapped (they sat on site for a while with trades putting other heavy items on them etc). In addition, they did sit in the rain for many weeks before being installed. I'm suspecting taking down the current sheets are too much work (I did ask directly, but was told that this is how the maintenance team has been addressing the existing builds). I've been told that it'll provide better insulation that way as well which I find questionable. Re: Builder wants to build new ceiling over defective ceilin 5May 06, 2024 1:54 pm defective work must be removed, and base prepared for new work Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Builder wants to build new ceiling over defective ceilin 6May 06, 2024 3:52 pm H A W U Ashington Homes H A W U G'day guys, During the PCI, we noticed that our Alfresco with feature rake ceiling had horrible quality. The sheets were all undulating, pretty much all nails were popping and the negative detail trimmers were all twisted and snapped at locations. The picture attached below is after they've patched it up and it's not even the worst location. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After many back and forth, builder admitted that they are rectifying a lot of their builds with this issue. They also admitted that it is not up to quality. They suggested to build new ceiling - However they are insistent on building it over the defective one, without taking them down first. We spoke to few ceiling fixers and they seem to be in line that to fix it properly, that the old defective one should be taken down first otherwise it'll cause issues down the track. Is this suggested solution by builder acceptable - Would you accept it? What is that product they have used? Also, do they know what is causing it and why won't they take down the current sheets? G'day @Ashington Homes, thanks for your reply. The material is Versilux Ceiling Lining and Trimmer is negative detail trimmer. In their words, 'Inferior level of finish is achieved on site caused by construction constraints of this product'. However, I've been on site everyday and they have proceeded to use trimmers (brackets between the sheets) which have significantly twisted, bent and snapped (they sat on site for a while with trades putting other heavy items on them etc). In addition, they did sit in the rain for many weeks before being installed. I'm suspecting taking down the current sheets are too much work (I did ask directly, but was told that this is how the maintenance team has been addressing the existing builds). I've been told that it'll provide better insulation that way as well which I find questionable. Thanks for the response. Now that I know what I am looking at I would like to slap your builder! It has to has to be removed. I can't understand why someone would say otherwise with a straight face. Sorry but you need to hold the line with this one Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Builder wants to build new ceiling over defective ceilin 7May 08, 2024 4:31 pm Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling installers, but I think it'll be quicker and better result for me to take the credit. Sorry to trouble you, but while you're here... Builder also missed all bottom weepholes on rendered walls (we're in WA so double brick with cavity). They put in the ones above windows, but not the vertical slit weepholes around the bottom every few meters. The bricklayers have put them in correctly but the renderers just closed them up. Site supervisor said it's standard practice for rendered walls, and while I give little credibility, I walked around the streets and it does look like all rendered walls have no weepholes put into them by most builders! He said they are more trouble / maintenance than not having them, and some clients specifically ask for bottom weepholes to be closed. Is this a big deal? We have cavity insulation (rockwool!! don't ask how we ended up with that. another blunder) If the build keeps returning, thats a plus!! but it would also suggest he doesnt know what his looking for, an independent inspector should have fresh eyes on the issue. Good luck 1 842 Sorry but you have a crap builder. Probably too late now. For our last build I only spoke to builders who would allow me easy access (at no cost). I used my own sparky… 10 10192 |
