Browse Forums Building A New House 1 May 01, 2024 4:32 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi All, Does anyone know if under CDC rules is a barrier mesh can be used for TPZ areas. I have about 40m worth of barrier and 2-3 on the nature strip. My builder quoted $1800.00 and ATF quoted for $2100 for a 24 mth rent. Hoping to find a cheaper alternative. TIA Re: CDC TPZ Barrier Mesh 2May 02, 2024 9:00 am Sleepless Knights Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi All, Does anyone know if under CDC rules is a barrier mesh can be used for TPZ areas. I have about 40m worth of barrier and 2-3 on the nature strip. My builder quoted $1800.00 and ATF quoted for $2100 for a 24 mth rent. Hoping to find a cheaper alternative. TIA I am 98% sure that orange stuff is not allowed. But you can check with your local council as it is their rangers who will give you grief. Normal practice is that you need to protect the trunk first of all. Wrap it with something soft like the white sediment barrier you get from bunnings. Then vertical timbers around the truck held in place with wire or speed bracing. Once you have done that you can fence the TPZ area off with stakes and metal fence mesh This wont cost anywhere near $1800. If you need me to explain more call me, happy to help Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: CDC TPZ Barrier Mesh 3May 02, 2024 9:32 am Ashington Homes Sleepless Knights Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi All, Does anyone know if under CDC rules is a barrier mesh can be used for TPZ areas. I have about 40m worth of barrier and 2-3 on the nature strip. My builder quoted $1800.00 and ATF quoted for $2100 for a 24 mth rent. Hoping to find a cheaper alternative. TIA I am 98% sure that orange stuff is not allowed. But you can check with your local council as it is their rangers who will give you grief. Normal practice is that you need to protect the trunk first of all. Wrap it with something soft like the white sediment barrier you get from bunnings. Then vertical timbers around the truck held in place with wire or speed bracing. Once you have done that you can fence the TPZ area off with stakes and metal fence mesh This wont cost anywhere near $1800. If you need me to explain more call me, happy to help Cheers Simeon Thanks Simeon, Would you have a some contacts so i can get a quote? Re: CDC TPZ Barrier Mesh 4May 02, 2024 6:02 pm Sleepless Knights Ashington Homes Sleepless Knights Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi All, Does anyone know if under CDC rules is a barrier mesh can be used for TPZ areas. I have about 40m worth of barrier and 2-3 on the nature strip. My builder quoted $1800.00 and ATF quoted for $2100 for a 24 mth rent. Hoping to find a cheaper alternative. TIA I am 98% sure that orange stuff is not allowed. But you can check with your local council as it is their rangers who will give you grief. Normal practice is that you need to protect the trunk first of all. Wrap it with something soft like the white sediment barrier you get from bunnings. Then vertical timbers around the truck held in place with wire or speed bracing. Once you have done that you can fence the TPZ area off with stakes and metal fence mesh This wont cost anywhere near $1800. If you need me to explain more call me, happy to help Cheers Simeon Thanks Simeon, Would you have a some contacts so i can get a quote? It is so easy to do yourself. Even if you are not very handy. You literally only need a few basic things from bunnings. Honestly even with the most basic skills I know you can succeed!. Save yourself money Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. MATE!!! I've checked their website and it's a 90% match at least. I've just called them and sent the pic through to confirm it's the same product. Thank you heaps. 3 6798 Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11967 Hi, I'm in the process of making a footing with two pieces of trench mesh (4L12TM ) at the top and bottom. I'm wondering if anyone knows how far beneath the top of the… 0 5072 |
