Does this gap between the door frame and the brick look like its within allowable expected natural ground movement ? It wasnt built like this and has over time moved.
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Does t
Browse Forums Building A New House Re: What is an allowable amount of movement? 2Apr 15, 2024 8:36 pm We are Expert Consultant's, and we are here to help. Re: What is an allowable amount of movement? 4Apr 15, 2024 8:56 pm We are Expert Consultant's, and we are here to help. Re: What is an allowable amount of movement? 7Apr 17, 2024 9:30 pm We are Expert Consultant's, and we are here to help. Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20740 Are they stumps or screw piles ? How much fill is there, is the site a class "P" ? A "H2" site is not supposed to have stumps it is supposed to have grid beams according… 1 7295 House movement is always a potential problem and there is a cause. Yes you should have it inspected by a competent and experienced building consultant 2 8692 |
