Browse Forums Building A New House Re: Front step at doorway 9Mar 25, 2024 7:33 am Take a pick with a level sittingo n the slab and a pick with a level sitting on the sill please. This will help us diagnose the issue and therefore a solution. RE, Slabs, its not a mandated inspection. Why, because trades are considered to be experts in their field with the neccesary training to not require an inspection at every step and the fact that the NCC and relevant Australian Standard dictates how everything is to be consdtucted and finished and it is expected (in a perfert world) that all trades build to code. These types of finishes occour with poorly trained, unqualified, non-caring workers. its an unfortunate occourance of the construction industry. Though this never happens and unless you have a building inspecter or someone familiar with codes and standards at every stage of the job you will have deficincies. its the nature of the game unfortunately. Building a house that meets every single code and standard is possible, but it takes siginifantly longer and costs more. It shouldnt, but thats building. the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12250 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 2072 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9296 |
