Browse Forums Building A New House 1 Mar 14, 2024 8:59 am Has anyone done this? Will it look strange? I don't use my 900 wide oven much but love the 900 cooktop. Since only two of us now we don't need a big oven. I'm just worried it will look strange with a larger cooktop above. Has anyone done this - can you show me a photo please Re: 900MM Cooktop over a 600MM built in oven 4Mar 15, 2024 9:19 am Denali Is a oven tower an option? We have a 900 induction stovetop with a duo oven tower. they said they dont use oven space of a 900, so 2x 600s while solving the aesthetics issue amplifies the original problem. Realistically the 2x 600 ovens is a way better solution from a kitchen usability perspective though Re: 900MM Cooktop over a 600MM built in oven 5Mar 15, 2024 9:42 am ponzutwo Denali Is a oven tower an option? We have a 900 induction stovetop with a duo oven tower. they said they dont use oven space of a 900, so 2x 600s while solving the aesthetics issue amplifies the original problem. Realistically the 2x 600 ovens is a way better solution from a kitchen usability perspective though OP could but a single 600mm oven in only? Westinghouse Duo is max height 890mm so smaller than 2 x 600. We are also a 2 adult only family and went with this as we see more use of the smaller oven (steamer & air fryer) oven for day to day use. https://www.westinghouse.com.au/cooking ... vep6727dd/. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 21681 Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would… 2 2237 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12201 |
