Browse Forums Building A New House 1 Mar 07, 2024 4:06 am Hi all, I’m building my house and had CDC approved. They made the retaining wall before the house slab. On one side, the gap between neighbour fence to garage wall is less than 900 mm and from neighbours fence to retaining wall is 500 mm that left the distance very tight. My question are: 1. under cdc what’s the minimum requirement need from garage wall to neighbour fence (boundary)? 2. What’s the walk way distance rules for walk way towards to existing granny flat at the back? Can anyone help me with my questions please. And if they build not as cdc required what will happen? This whole building process has been giving me so much stress as I have away from my house for more than 2 years. Re: Retaining wall to garage wall 2Mar 07, 2024 8:04 am vivi 1907 Attached are the setbacks taken from page 149 of the State Environmental Planning Policy (Exempt and Complying Development Codes) 2008 Basically, at the end of the build you have a surveyor do an ident or identification survey and if the home is in the wrong location you won't get an occupation certificate. If it were me I would be getting the surveyor to double check that the retaining walls are actually built on the boundary before doing anything else. I also want to add that if you need your CDC modified that is a pretty simple process. I hope this help a bit Cheers Simeon Side setbacksLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Retaining wall to garage wall 3Mar 07, 2024 9:54 am Hi Simeon, Thank you so much for your explanation. If the garage wall count as the start point to boundary for 900 mm? I booked private building inspector, can he check on this as well? Thanks again Regards Vivi Re: Retaining wall to garage wall 4Mar 07, 2024 10:06 am vivi1907 Hi Simeon, Thank you so much for your explanation. If the garage wall count as the start point to boundary for 900 mm? I booked private building inspector, can he check on this as well? Thanks again Regards Vivi Vivi I believe it will, however there is one massive caveat to my advice. We specialise in KDRBs in established suburbs so I have zero experience in new housing estates which allow for zero lot boundaries ( if that is what they are called), so I am not sure how these work. Is there any way you can talk to the certifier who approved your home and get some advice? Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16509 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7176 Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You… 1 8474 |
