Browse Forums Building A New House 1 Feb 21, 2024 10:04 pm Any insulation experts please advise as I am planning to do following insulation. It's my first two storey home in framing stage in NSW. 1. All internal walls in both floors. 2. External wall of Garage as I will use as office. 3. Ground floor Ceiling insulation between floors including Garage ceiling and Alfresco. 4. Plumbing pipes. what kind of insulation product and type is best for internal walls, ceiling, pipes. Do I still need to go for plumbing pipe insulation as I will do for internal floors. Kindly guide me Re: Insulation for Internal wall, between floors 2Feb 23, 2024 9:11 am Why would you want to insulate internal walls, it makes no sense. The critical insulation is your external building envelope. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Insulation for Internal wall, between floors 3Feb 23, 2024 4:20 pm Insulating internal walls is a good idea - I always do it. Helps reduce noise transmission and helps with thermal insulation. Do you want thermal insulation or acoustic insulation? It makes a difference. Speak with your builder (after doing some research). Has this issue not already been discussed and resolved during the design stage? Re: Insulation for Internal wall, between floors 4Feb 26, 2024 10:11 am building-expert Why would you want to insulate internal walls, it makes no sense. The critical insulation is your external building envelope. some of my internal walls are common between two bedroom between bedroom and toilet between bedroom and living and theatre. main intension is to reduce noise transmission between rooms and also with thermal insulation to keep the temperature roomwise. its not common but thought worth doing it. please share ur thoughts thanks Re: Insulation for Internal wall, between floors 5Feb 26, 2024 10:15 am gommeqld Insulating internal walls is a good idea - I always do it. Helps reduce noise transmission and helps with thermal insulation. Do you want thermal insulation or acoustic insulation? It makes a difference. Speak with your builder (after doing some research). Has this issue not already been discussed and resolved during the design stage? yep i did and asked builder for insulation and he advise can be added as upgrade during framing stage. so now it framing stage and wants to do this. any idea how much it may cost as am planning do the following (GF 170sqm & FF 130sqm): 1. All internal walls in both floors. 2. External wall of Garage as I will use as office. 3. Ground floor Ceiling insulation between floors Re: Insulation for Internal wall, between floors 6Feb 26, 2024 11:17 am Sorry, don't know costs, but there are a couple of very important principles you need to get right (and now) .... (1) never agree to any "upgrade" unless you first know and agree to the cost. (2) never agree to any cost unless you have a basic idea on whether the cost is fair. (3) your designer should be helping with these questions. If not, find another designer. If you do not have a designer then hire a building inspector. Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9202 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 8019 3 10254 |
