Browse Forums Building A New House Re: Help Staircase void too small 3Jan 30, 2024 4:42 pm radiuz Would you consider changing your square landing step to 2 diagonal steps and then you would not need to change the beams? Otherwise if the steel beams are in the ceiling cavity, you won't even see the difference visually. Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm not sure how does it look like after the change. To me, that's what it looks like: poor backfilling and/or compaction. The width is about 1000mm maybe. That conduit in the photo is for the NBN. The water is about… 4 8511 Staircases and sausages. Should thou wish to keep thy palate sweet for sausages, avert thine eyes from their crafting. 14 4875 |
