Browse Forums Building A New House 1 Feb 07, 2024 6:56 pm Hi there, We are building a new house in NSW. Our builder had the carpenter install skirting/architraves etc.., but there are some noticeable gaps in some places. These gaps appear to be way over the acceptable tolerances. (window trim is the bathroom that will have full wall heigh tiles installed) Should we push on the builder to get these redone? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Skirting/Windows Trim acceptable tolerance/gaps 2Feb 07, 2024 7:33 pm Yes this is dreadful fixing Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Skirting/Windows Trim acceptable tolerance/gaps 4Feb 07, 2024 8:33 pm Unless documented otherwise, gaps between mouldings or between mouldings and other fixtures, at mitre or butt joints, or at junctions with a wall or other surfaces, are defective if they exist at handover, or exceed 1 mm in width within the first 12 months of completion and are visible from a normal viewing position. After the first 12 months, gaps are defective if they exceed 2 mm in width and are visible from a normal viewing position. Gaps between skirting and flooring are defective if they exceed 2 mm within the first 24 months after handover and are visible from a normal viewing position. We are Expert Consultant's, and we are here to help. Re: Skirting/Windows Trim acceptable tolerance/gaps 5Feb 07, 2024 9:08 pm Thanks for the inputs. I am guessing the builders plan is to caulk the gaps which would probably technically fit within the limits specified . Still, the workmanship looks very poor to me. Re: Skirting/Windows Trim acceptable tolerance/gaps 6Feb 08, 2024 11:42 am Perhaps the windows can be released, then pushed out hard up against the plaster wall and refixed, however your first photo shows bow in a wall. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Skirting/Windows Trim acceptable tolerance/gaps 7Feb 08, 2024 12:25 pm pzele Hi there, We are building a new house in NSW. Our builder had the carpenter install skirting/architraves etc.., but there are some noticeable gaps in some places. These gaps appear to be way over the acceptable tolerances. (window trim is the bathroom that will have full wall heigh tiles installed) Should we push on the builder to get these redone? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That is horrible work! The window reveals should have been planed down before fixing and the skirts make it look like your walls are out of alignment. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Skirting/Windows Trim acceptable tolerance/gaps 8Feb 08, 2024 12:26 pm pzele Thanks for the inputs. I am guessing the builders plan is to caulk the gaps which would probably technically fit within the limits specified . Still, the workmanship looks very poor to me. Caulking gaps that big will look horrible Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. B, You and I know each other well outside of the forum, and I really like you. So I am not meaning any ill will by the following comments. I have been with you on this… 7 1717 Building Standards; Getting It Right! Is this acceptable in a new house build. Floors where installed by builder. Already chips in board and skirting is not flush 0 873 |
