Browse Forums Building A New House 1 Nov 12, 2023 12:12 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hello everyone. Does the valley in above pictures comply with the NCC? From the looks of it, they've used some really wide valley gutter and screwed the ridge cap directly onto the valley. Not to mention there is a lot of buckling / warping of both ridge cap and the valley gutter. Not sure why they didn't have colorbond sheet, there are 3 valleys that are like this. We have a building inspector so we will enquire with him, but I also wanted to check in with anyone familiar with NCC here. Looking at the NCC, typical valley gutter should look like this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any expertise much appreciated. Thank you! Re: NCC - Roof Valley - Does this comply? 3Nov 13, 2023 10:44 am can you post roof plan? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: NCC - Roof Valley - Does this comply? 5Nov 13, 2023 1:03 pm You really have nothing for the water running down the corrugated sheets to oppose it from running under the Ridge capping.
Not sure if it's standard on valleys, but my valley flashing were over bent past 90 degrees. Re: NCC - Roof Valley - Does this comply? 7Nov 13, 2023 5:36 pm Yes thats what I am thinking. The upturn under the sheet on the valley piece directs this flow down the valley.
As I miss edited the wrong post.. Not sure if its standard, but my valley flashing was over bent past 90 degrees. Re: NCC - Roof Valley - Does this comply? 8Nov 13, 2023 5:38 pm Ardo Yes thats what I am thinking. The upturn under the sheet on the valley piece directs this flow down the valley. Yes, the new requirement for the upturn was added in the NCC update in 2022 for this reason supposedly. With the driving wind, they were finding situations where you still get the water into the roof from the valley. Re: NCC - Roof Valley - Does this comply? 9Nov 14, 2023 3:07 pm The photos show lack of workmanship and aesthetic appearance, and the roof does not follow roof plan in breach of builders warranties. Yes its defective. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: NCC - Roof Valley - Does this comply? 10Nov 14, 2023 3:08 pm building-expert The photos show lack of workmanship and aesthetic appearance, and the roof does not follow roof plan in breach of builders warranties. Yes its defective. G'day, could you please help clarify which part doesn't follow the roof plan? Re: NCC - Roof Valley - Does this comply? 12Nov 14, 2023 6:01 pm Ardo Perhaps the little lines under the highlighted bit that identify it as being corrugated to the valley? Yes, correct Ardo. Would anyone in their right mind accept the roof as built when it is drawn as corrugated to the valley? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: NCC - Roof Valley - Does this comply? 13Nov 14, 2023 6:08 pm building-expert Ardo Perhaps the little lines under the highlighted bit that identify it as being corrugated to the valley? Yes, correct Ardo. Would anyone in their right mind accept the roof as built when it is drawn as corrugated to the valley? thanks guys! yes this is how I've exactly raised it with the builder. still awaiting response. I am trying to find lighting for kitchen, dining areas but looking online, I don’t know if there are specific details I should be looking at to make sure any lights I… 0 10792 Whats in the gap between the fence and the concrete? I assume dirt/plants etc, right? like youve shown in other parts of the pics. Im not sure how familiar you are with… 8 6219 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 2384 |
