Browse Forums Building A New House 1 Sep 08, 2023 4:13 pm Can someone advise if my roof flashing is ok ? do they look compliant ? We didn't elect to use zincalume . shouldn't this be colour bond as colour bond was used everywhere else . It looks like a bad patch work . There is silicon between the zincalume and brick. Is this the proper way of doing it ? Thanks so much ! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ? Re: ROOF FLASHING 2Sep 10, 2023 8:16 pm Yes it should have been colorbond and no its not compliant. Pressure flashing must be fixed to wall not exceeding 100 mm centres. Workmanship is sub standard and non matching flashing widths are not acceptable. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: ROOF FLASHING 3Mar 20, 2024 11:40 am I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf Coming back to this.... When installing a pressure flashing, what fixings would you use (please give a link) ? Above Pedro said nylon anchors. Anyone have a preferred… 7 11815 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6824 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10807 |
