Browse Forums Building A New House 1 Jul 16, 2023 9:30 am Hi Everyone, My house is almost complete but due to the lower position of the Garage boundary wall compared to the neighbor side, i am very concerned about the potential issues with this wall in the future if too much water on there, even this wall has been rendered (Hebel Wall). Are there any recommended outdoor waterproof paints or other high tech sealers that can be applied to the base of the boundary wall to protect the foundation and the surface both render and hebel? Thanks heaps!! Re: URGENT·····Garage Boundary Wall Water Proofing Issue 2Jul 17, 2023 10:18 pm Hebel cannot retain, it can’t have dirt against it no matter you paint it with. If you have lowered the natural ground level then you need to urgently redesign this. If you have build above NGL then the adjacent owner is not meant to fill against the wall. They usually do anyway so that is the problem with henkel on the boundary. Termite protection also is an issue. Re: URGENT·····Garage Boundary Wall Water Proofing Issue 3Jul 17, 2023 10:33 pm You can use black building plastic, under your agi drain and up the wall Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: URGENT·····Garage Boundary Wall Water Proofing Issue 4Jul 17, 2023 11:49 pm Pulse Hebel cannot retain, it can’t have dirt against it no matter you paint it with. If you have lowered the natural ground level then you need to urgently redesign this. If you have build above NGL then the adjacent owner is not meant to fill against the wall. They usually do anyway so that is the problem with henkel on the boundary. Termite protection also is an issue. Hi Pulse, the hebel has been rendered already so guess render has somewhat waterproofing? I bought an exterior rubber based waterproofing membrane, hope it works. Re: URGENT·····Garage Boundary Wall Water Proofing Issue 5Jul 17, 2023 11:58 pm building-expert You can use black building plastic, under your agi drain and up the wall yep, i will use black plastic to cover the wall bottom after i do paint. hopes no drama. Re: URGENT·····Garage Boundary Wall Water Proofing Issue 6Jul 18, 2023 1:00 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That's the detail from CSR. Hopefully you won't have to much soil height stacked against the wall, and hopefully your builders have applied the sealer along the underside of your Hebel panels before installation otherwise you will always have potential of moisture wicking up from underneath. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: URGENT·····Garage Boundary Wall Water Proofing Issue 7Jul 18, 2023 10:51 am I would be getting corflute Dig down to expose slab edge and panel bottom and get sheet down into ground Can screw off neatly with a small roofing type screw and then seal with polyurethane everywhere. Re: URGENT·····Garage Boundary Wall Water Proofing Issue 8Jul 18, 2023 1:16 pm chars0974 Hi Everyone, My house is almost complete but due to the lower position of the Garage boundary wall compared to the neighbor side, i am very concerned about the potential issues with this wall in the future if too much water on there, even this wall has been rendered (Hebel Wall). Are there any recommended outdoor waterproof paints or other high tech sealers that can be applied to the base of the boundary wall to protect the foundation and the surface both render and hebel? Thanks heaps!! Chars The best advise I can give you is call Christian at the Waterproofing Shop in Lakemba. The guy is an absolute guru and sells all of the high quality waterproofing products to the professionals. When I say he is a guru, he literally is and is more than happy to give advice. His number is 0411 753 684 Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: URGENT·····Garage Boundary Wall Water Proofing Issue 9Jul 19, 2023 12:13 am chippy Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That's the detail from CSR. Hopefully you won't have to much soil height stacked against the wall, and hopefully your builders have applied the sealer along the underside of your Hebel panels before installation otherwise you will always have potential of moisture wicking up from underneath. thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. It worked for me in getting all non notified rain days removed from the builders claim, although the LDs was only $50/day 7 6121 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17437 In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7272 |
