Browse Forums Building A New House 1 Jun 07, 2023 3:56 pm I am currently building a Duplex in Ryde Council area with a project builder. After the electrical appointment, I was quoted additional Temporary Underground Power Services Provisions to 2nd dwellings for around $5K due to the area is under Ausgrid. This cost doesn't include the permanent power connection to the 2nd dwellings upon subdivision approvals. My questions are below; Is it normal for builder or electrical company charge us for this temporary power to the 2nd dwellings (It should be ready to move in for all the building cost mentioned in HIA tender)? What if, I don't want to proceed with them and will I get no power supply to the 2nd dwellings? What is your experiences in dealing with such situations and any recommendations? Thanks. JW. Re: Duplexes with Temporary Underground Services 2Jun 15, 2023 1:07 pm jimmywky I am currently building a Duplex in Ryde Council area with a project builder. After the electrical appointment, I was quoted additional Temporary Underground Power Services Provisions to 2nd dwellings for around $5K due to the area is under Ausgrid. This cost doesn't include the permanent power connection to the 2nd dwellings upon subdivision approvals. My questions are below; Is it normal for builder or electrical company charge us for this temporary power to the 2nd dwellings (It should be ready to move in for all the building cost mentioned in HIA tender)? What if, I don't want to proceed with them and will I get no power supply to the 2nd dwellings? What is your experiences in dealing with such situations and any recommendations? Thanks. JW. Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the dwellings. Depending which Level 2 contractor you use the cost is normally between $4-5k. The level 2 contractor sends us the the paper work and applies for a connection. When we are ready for the 2nd dwelling, they come and install a second pole for a similar price. You need this connection so the electrician can connect and test everything. In your case it sounds like they are doing a temporary connection for the second unit and then you have to apply for your own permanent pole. The joys of project home building. You need to find a level 2 electrician early as the wait can be a killer. all the best Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. 1 4117 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 3637 Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1903 |
