Browse Forums Building A New House 1 Apr 14, 2023 2:51 pm Hi all, Trying to workout the minimum stepdown required between slab for my house and the outdoor alfresco area. Garage is 100mm lower than rest of the house and plan was to do the same for alfresco but I've been told that 100mm is the minimum height difference so once lay down outdoor tiles the difference between inside and outside will be less than 100mm and is non compliant. Presumably there is something in the BCA/NCC or an Australian Standard but I can't seem to find the specific reference. Thanks Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4228 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4941 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1707 |
