We are at roofing stage and I want to change my toilet to one with a concealed cistern in the wall cavity.
Our builder said it is too late to change as they have roughed in the plumbing.
Is this correct?
Many thanks for your ideas.
Browse Forums Building A New House 1 Sep 27, 2022 2:45 pm We are at roofing stage and I want to change my toilet to one with a concealed cistern in the wall cavity. Our builder said it is too late to change as they have roughed in the plumbing. Is this correct? Many thanks for your ideas. Re: Concealed cistern 6Sep 28, 2022 8:42 am The cisterns only need 90mm ie std external wall frame, issue is the pan and waste set out. I’d think <$1000 easy , 2 hours for the plumber and 1hr framing, there could be other issues without seeing the situation Re: Concealed cistern 7Sep 30, 2022 6:04 pm Pulse The cisterns only need 90mm ie std external wall frame, issue is the pan and waste set out. I’d think <$1000 easy , 2 hours for the plumber and 1hr framing, there could be other issues without seeing the situation Builder is now looking into how much it will cost to change. I’ll let you know the price. Thanks for your support Re: Concealed cistern 8Sep 30, 2022 6:10 pm Mirrmu83 $1000's carpenter to modify/customize framing, may need double frame to conceal unit different cistern and bowl plumbing have to be modified builders margin Sounds like a lot of work and maybe not worth it just for the aesthetic look. Re: Concealed cistern 9Oct 12, 2022 5:29 pm Marge1 Pulse The cisterns only need 90mm ie std external wall frame, issue is the pan and waste set out. I’d think <$1000 easy , 2 hours for the plumber and 1hr framing, there could be other issues without seeing the situation Builder is now looking into how much it will cost to change. I’ll let you know the price. Thanks for your support Came back at a cost of $1200. You were spot on. Many thanks Yes, get a builder, make sure he is experienced and a registered building practitioner 5 9179 |
