Browse Forums Building A New House 1 Aug 20, 2021 10:11 am We're building a 3-storey steel-frame house in Brisbane, and we're trying to understand what we should be looking for in terms of acoustic and thermal insulation (our builder is not very helpful, according to them anything would in Brisbane). Half of the ground level floor (has media room and garage) is inside of a hill and blocks are used for the part that is not - no insulation there, apart from the plasterboard. Roof, sides and back of the house are Colorbond, and front of the house has lot of big windows and wheathertex. What we have at the moment in terms of insulation (according to our builder): * R2.5 glasswool bats for external walls for mid and top levels * R2.5 glasswool bats in top level ceiling * Acoustic insulation on all internal walls (don't know which one) So my questions to the wise homeone community would be: * Does the above look enough, for our build ? * Should we add acoustic insulation between the floors as well ? The last thing I want it people in dining listening to the sounds of someone flushing toilet in ensuit * If between-floors acoustic insulation is a good idea - any recommendations on particular type ? I didn't find anything on Bunnings website: all acoustic batts were for walls, and I'm not sure if they can be used in ceiling. * I read horror stories about steel-frame houses being very noisy sometimes. Is there anything we can do cheaply to reduce the noise to a minimum ? * Do we need to do anything additional about the ground level ? We could install thermal insulation there, but it would eat up internal space, plus we're not sure how much value it would add. Any recommendations would be very appreciated ! Re: New 3-storey steel frame house insulation - advise neede 2Aug 21, 2021 1:37 pm
plus they will be certified by trusted engineers Here CFD 3 storey town house
When searching Bim .....Please don't confused Architectural/Artistic Bim with Engineering multiphysics Bim Engineering Bim is licensed to perform as per the data/proofs... Architectural/Artistic Bim is visual Fantasy Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New 3-storey steel frame house insulation - advise neede 3Aug 22, 2021 9:42 am There's a difference between what you need to do to pass bare minimum requirements, and what you should do (if you have the budget) to live in the house comfortably. I would most definitely put sound insulation in all internal walls, as well as between the floors. Rockwool seems to be the popular one, plus you can consider acoustic plasterboard for rooms that will generate a lot of noise. Also I'd go for concrete tiled roof, if noise is a concern. Colorbond will be noisy when it rains. Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14965 This is 100% true. You can not hang anything on steel frames. very frustrating 8 10390 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 9268 |
