Browse Forums Building A New House 1 Dec 30, 2020 7:39 am Hi Im wanting some red brick inspiration if possible. It doesnt seem to be the 'in-thing' for new builds in qld. We are doing an acerage build where everything else is pretty much cream and beige so I want to stand out. Has anyone used Austral Paprika or Stimulate with night sky or monument accent? Or even any of the Austral red brick range? Tia From the visualiser: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Austral red brick inspiration 2Dec 30, 2020 11:20 am Haven’t built yet so can’t help with pics but we decided to go Austral Access Ruby with Pale Eucalypt roof. We are building in outskirts of Melbourne. Quite a few older properties around us that are similar. I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6941 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21354 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8888 |
