Yeah I've been a bit flat all day as I was hoping from here we would have keys in about two weeks but now it will be more like 4 weeks or so
Browse Forums Building A New House Re: Building Metricon Glendale 42 Limited Edition in Geelong 2421Mar 17, 2017 7:53 pm bank Bugger! That would be disappointing. Hopefully everything is good to go next time. A pre-PCI might turn out to be a blessing. Yeah I've been a bit flat all day as I was hoping from here we would have keys in about two weeks but now it will be more like 4 weeks or so Re: Building Metricon Glendale 42 Limited Edition in Geelong 2422Mar 18, 2017 10:38 am Cool tiles to have as your kitchen return. Re: Building Metricon Glendale 42 Limited Edition in Geelong 2423Mar 18, 2017 8:06 pm kylz4 bank Bugger! That would be disappointing. Hopefully everything is good to go next time. A pre-PCI might turn out to be a blessing. Yeah I've been a bit flat all day as I was hoping from here we would have keys in about two weeks but now it will be more like 4 weeks or so Hope it won't be that long Kylz your almost there ?? Re: Building Metricon Glendale 42 Limited Edition in Geelong 2424Mar 23, 2017 7:56 am Ok so finally got a date out of site manager.... reluctantly so not putting too much hope on it!! 13th April fir the next inspection!!! That's 4 weeks after our waste of time and money 'PCI' that we had! Then handover 1-2 weeks after that depending what is found! Re: Building Metricon Glendale 42 Limited Edition in Geelong 2425Mar 23, 2017 7:58 am Oh yeah! Let's hope they are ready in 4 weeks time @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2426Mar 23, 2017 7:59 am They better be but I have little faith Re: Building Metricon Glendale 42 Limited Edition in Geelong 2428Mar 23, 2017 9:56 am Oh i see. Your alfresco was put together by elephants using their trunks to build your corner bricks .... Our alfresco is not as bad as yours. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2429Mar 23, 2017 10:17 am Lol yes I think so Orph! Here is list from our PCI * vapour barrier covered up near porch * smartpan waste installed instead of closet pan - was told this would be fine for our toilets but it's still on report!? * thick bed joints all around * gaps in mortar * weep holes have mortar in them that needs to be scraped out * painting incomplete and lots to fix up * nail patches visible to all door frames * incorrect screws used to anchor downpipes * roof tiles misaligned * downpipe installed over electrical wire - they have just pulled wire along mortar and installed JB over a few cms * not enough clips holding up guttering * brown discolouration to mortar joint from too strong acid wash * marks all over concrete to garage and alfresco - needs to be scraped up or a layer poured on top * poorly installed caulking between bricks * tops of internal windows and doors not sealed * broken pipe outside * no door seals to garage entry door * metal strip not secured over floorboards near stacker door * electrical points not level/plumb * sink in kitchen not sealed * tiles cut with jagged edges * Toilets installed with silicone instead of screws!!!!! * chips to ensuite Benchtops * carpet/tile joins poorly finished * all robe doors need to be adjusted * walkway from manhole to ducted heating unit has several hazards * roofspace insulation needs to be fixed up * heater flue requires bracket * out of level Benchtops to bathroom and powder room (tilting forward) * hitters need to be cleaned - mortar, nails, pop rivets, cracked tiles * incomplete render/blinds/external painting/staining to door and stairs That's was from inspector... this was also from us! * lots of paint fix ups * lights not aligned * differing grout thickness * missing grout to areas in balcony * cavity doors not installed to ensuite * Plaster fix up to reveal behind overhead cupboards * scratches/dents to stacker door frames and rear garage roller Can't believe our SM even booked in PCI with so many issues!!! Re: Building Metricon Glendale 42 Limited Edition in Geelong 2430Mar 23, 2017 10:25 am Maybe yr SM was visually impaired and couldn't see??? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2432Mar 23, 2017 1:43 pm Ssjo Could i ask what is PCI? Thanks in advance. PCI is supposed to be final walkthrough when everything is finished and you mark any issues for them to fix prior to handover. Ours was so big that we have to do PCI again once they have fixed everything up. Hoping there won't be many issues picked up at next one though and handover will be quite quick Re: Building Metricon Glendale 42 Limited Edition in Geelong 2433Mar 23, 2017 1:44 pm Orpheus Maybe yr SM was visually impaired and couldn't see??? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Or he has no clue Re: Building Metricon Glendale 42 Limited Edition in Geelong 2434Mar 23, 2017 1:50 pm kylz4 Ssjo Could i ask what is PCI? Thanks in advance. PCI is supposed to be final walkthrough when everything is finished and you mark any issues for them to fix prior to handover. Ours was so big that we have to do PCI again once they have fixed everything up. Hoping there won't be many issues picked up at next one though and handover will be quite quick Thanks Re: Building Metricon Glendale 42 Limited Edition in Geelong 2435Mar 23, 2017 1:52 pm Ssjo kylz4 Ssjo Could i ask what is PCI? Thanks in advance. PCI is supposed to be final walkthrough when everything is finished and you mark any issues for them to fix prior to handover. Ours was so big that we have to do PCI again once they have fixed everything up. Hoping there won't be many issues picked up at next one though and handover will be quite quick Thanks I have the luxury of doing PCI every day (I have special access) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 2436Mar 23, 2017 1:53 pm kylz4 PCI is supposed to be final walkthrough when everything is finished and you mark any issues for them to fix prior to handover. Ours was so big that we have to do PCI again once they have fixed everything up. Hoping there won't be many issues picked up at next one though and handover will be quite quick How do we go about the PCI? Does the SM walk along with us while we go through, or do we get a free run to go through in as much detail and then report based on that? The reason i ask is.. when i used to enter the house when unlocked during the build stage, i used to get time to look at stuff at my pace, which i then used for my reference, as well as to ask questions if needed. When i did my last walkthrough along with the SM, i got to look at stuff, but having someone along kinda reduced my thought process and freedom to explore. Re: Building Metricon Glendale 42 Limited Edition in Geelong 2437Mar 23, 2017 1:56 pm qldben kylz4 PCI is supposed to be final walkthrough when everything is finished and you mark any issues for them to fix prior to handover. Ours was so big that we have to do PCI again once they have fixed everything up. Hoping there won't be many issues picked up at next one though and handover will be quite quick How do we go about the PCI? Does the SM walk along with us while we go through, or do we get a free run to go through in as much detail and then report based on that? The reason i ask is.. when i used to enter the house when unlocked during the build stage, i used to get time to look at stuff at my pace, which i then used for my reference, as well as to ask questions if needed. When i did my last walkthrough along with the SM, i got to look at stuff, but having someone along kinda reduced my thought process and freedom to explore. We had the sm with us and he had the roll of tape so anything we found we had to point out for him to put tape on. At our last build we were given our own tape and went around ourselves marking things as did the SM. The way we did it this time felt very uncomfortable. I still took my time though, he didn't try to rush us along at least. Re: Building Metricon Glendale 42 Limited Edition in Geelong 2438Mar 23, 2017 3:35 pm Far out Kylz. That's a list! Mine is about the same at the moment lol. Better now than after handover though. My toilets are only installed with silicone too... Where would they even screw them? Now I'm worried lol C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Building Metricon Glendale 42 Limited Edition in Geelong 2439Mar 23, 2017 7:42 pm Wow what a list!! I hope they get them all sorted for you! Clearly your SM has no idea about quality! Build thread: viewtopic.php?f=31&t=78995 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12162 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9551 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19624 |
