Browse Forums Building A New House Re: We are building VANCOUVER 33 with PORTER DAVIS 241May 18, 2017 12:56 pm If what I have been told is correct we don't require a planning permit so just council approval, then the surveyor organises the building permit.. does that make sense? Re: We are building VANCOUVER 33 with PORTER DAVIS 242May 18, 2017 1:04 pm nikil If what I have been told is correct we don't require a planning permit so just council approval, then the surveyor organises the building permit.. does that make sense? sorry i was just referring to Sgene's comment... you guys are different building in a established area. Re: We are building VANCOUVER 33 with PORTER DAVIS 243May 18, 2017 1:05 pm Hey Liz! For us our BC said that PD permits team have applied for the developers approval and waiting for developers response. The building permit will then be lodged once the block has titled (expected next week) and we have received all of the property information from council and the developer. So we should expect to be at site start, from early July. Fingers crossed. Yes, I believe so. Everyone seems to say to get a private independent inspector. Did you get one? Any recommendations? Re: We are building VANCOUVER 33 with PORTER DAVIS 244May 18, 2017 1:55 pm Sgene85 Hey Liz! For us our BC said that PD permits team have applied for the developers approval and waiting for developers response. The building permit will then be lodged once the block has titled (expected next week) and we have received all of the property information from council and the developer. So we should expect to be at site start, from early July. Fingers crossed. Yes, I believe so. Everyone seems to say to get a private independent inspector. Did you get one? Any recommendations? ahhh perhaps developer approval is much like council approval for us in established areas. makes sense! the permit is the last step after either developer or council approval. Fingers crossed! and hopefully winter wont hold anything up either. I remember December being a very quiet month too. Definitely, esp if you want things done the right way or to have piece of mind your on track. Major issues can cause huge delays. Did you see jennys issues on instagram, they basically had to pull the house down post plaster and start again. It was terrible. She too is building the Vancouver. We used New homes inspections, they were great. Re: We are building VANCOUVER 33 with PORTER DAVIS 245May 18, 2017 2:28 pm lizbf85 Sgene85 Hey Liz! For us our BC said that PD permits team have applied for the developers approval and waiting for developers response. The building permit will then be lodged once the block has titled (expected next week) and we have received all of the property information from council and the developer. So we should expect to be at site start, from early July. Fingers crossed. Yes, I believe so. Everyone seems to say to get a private independent inspector. Did you get one? Any recommendations? ahhh perhaps developer approval is much like council approval for us in established areas. makes sense! the permit is the last step after either developer or council approval. Fingers crossed! and hopefully winter wont hold anything up either. I remember December being a very quiet month too. Definitely, esp if you want things done the right way or to have piece of mind your on track. Major issues can cause huge delays. Did you see jennys issues on instagram, they basically had to pull the house down post plaster and start again. It was terrible. She too is building the Vancouver. We used New homes inspections, they were great. I'm pretty sure that if you are buying a block of land in a new estate you have to get both developer approval and council approval. I think the developer focuses mostly on that it fits in with the rest of the neighborhood and the council does the same as well as checking the engineering perhaps? In any case it seems like in my case at least we need both. We're in the process of applying for developer approval at the moment which is proving frustrating because of the lack of internal communication at PD with one department not telling another department about changes which need to be made until after contract, once the block titles and we have developer approval we can then go for council approval. Building a Kew 28 with Porter Davis Re: We are building VANCOUVER 33 with PORTER DAVIS 246May 22, 2017 6:33 am lizbf85 Sgene85 Hey Liz! For us our BC said that PD permits team have applied for the developers approval and waiting for developers response. The building permit will then be lodged once the block has titled (expected next week) and we have received all of the property information from council and the developer. So we should expect to be at site start, from early July. Fingers crossed. Yes, I believe so. Everyone seems to say to get a private independent inspector. Did you get one? Any recommendations? ahhh perhaps developer approval is much like council approval for us in established areas. makes sense! the permit is the last step after either developer or council approval. Fingers crossed! and hopefully winter wont hold anything up either. I remember December being a very quiet month too. Definitely, esp if you want things done the right way or to have piece of mind your on track. Major issues can cause huge delays. Did you see jennys issues on instagram, they basically had to pull the house down post plaster and start again. It was terrible. She too is building the Vancouver. We used New homes inspections, they were great. We are building on new land and needed developer approval first, then planning permit (which cost over $1000 to council), then council approval, then building permit (which came through a week after council approval). We got our site start date a few weeks after the building permit was approved. - View my blog at www.waldorfgrangebuild.wordpress.com Re: We are building VANCOUVER 33 with PORTER DAVIS 247May 22, 2017 6:36 am Waldorf_Grange_Build We are building on new land and needed developer approval first, then planning permit (which cost over $1000 to council), then council approval, then building permit (which came through a week after council approval). We got our site start date a few weeks after the building permit was approved. - View my blog at http://www.waldorfgrangebuild.wordpress.com Did you have to pay for the planning permit or does PD pay for that? I'm assuming we will need a planning permit as well but PD haven't mentioned anything about it or the cost. Building a Kew 28 with Porter Davis Re: We are building VANCOUVER 33 with PORTER DAVIS 248May 22, 2017 6:59 am Hurrow Waldorf_Grange_Build We are building on new land and needed developer approval first, then planning permit (which cost over $1000 to council), then council approval, then building permit (which came through a week after council approval). We got our site start date a few weeks after the building permit was approved. - View my blog at http://www.waldorfgrangebuild.wordpress.com Did you have to pay for the planning permit or does PD pay for that? I'm assuming we will need a planning permit as well but PD haven't mentioned anything about it or the cost. We had to pay. It was listed on our council website. The pricing varied depending on the value of the build. PD didn't mention to us either as the council approval part was our responsibility so we just called the council and asked what the procedure was. - View my blog at www.waldorfgrangebuild.wordpress.com Re: We are building VANCOUVER 33 with PORTER DAVIS 250May 23, 2017 1:29 pm Sgene85 Hey all, our block titled yesterday!!!! Wohooo!!! Settlement in two weeks. I'm waiting for BC to get back to me on our build. Woo hoo. Great news. Re: We are building VANCOUVER 33 with PORTER DAVIS 251May 23, 2017 1:45 pm Sgene85 Hey all, our block titled yesterday!!!! Wohooo!!! Settlement in two weeks. I'm waiting for BC to get back to me on our build. Woohoo, great news! Any idea when PD is likely to be able to start the build, what is the start date in the contract? Building a Kew 28 with Porter Davis Re: We are building VANCOUVER 33 with PORTER DAVIS 252May 23, 2017 3:18 pm Waldorf_Grange_Build Hurrow Waldorf_Grange_Build We are building on new land and needed developer approval first, then planning permit (which cost over $1000 to council), then council approval, then building permit (which came through a week after council approval). We got our site start date a few weeks after the building permit was approved. - View my blog at http://www.waldorfgrangebuild.wordpress.com Did you have to pay for the planning permit or does PD pay for that? I'm assuming we will need a planning permit as well but PD haven't mentioned anything about it or the cost. We had to pay. It was listed on our council website. The pricing varied depending on the value of the build. PD didn't mention to us either as the council approval part was our responsibility so we just called the council and asked what the procedure was. - View my blog at http://www.waldorfgrangebuild.wordpress.com Can I also add to this list of permits that there is also "Asset Protection Permit" which is a council permit. I am not sure if this type of permit applies to all council but it does for Casey Council. In my case the builder paid for it. What is it? "Asset protection helps the City of Casey protect its valuable infrastructure assets from any damage that may occur during building or demolition works (including the delivery of any materials and equipment). If damage occurs, Council can recover the costs of repair from permit holders, rather than ratepayers. " You can find out more here Asset Protection Permit - Casey Council Building the Madison 40 | By Porter Davis Re: We are building VANCOUVER 33 with PORTER DAVIS 253May 23, 2017 3:56 pm Sgene85 Hey all, our block titled yesterday!!!! Wohooo!!! Settlement in two weeks. I'm waiting for BC to get back to me on our build. awesome news! hopefully you guys can start soon Re: We are building VANCOUVER 33 with PORTER DAVIS 254May 23, 2017 4:03 pm Our initial site start was March 2017 but that was based on the original time frame that our block would title Dec 2016. That obviously didn't happen. My estimate is that we will start around July. Thanks all Re: We are building VANCOUVER 33 with PORTER DAVIS 255May 30, 2017 1:56 pm Hi All, A quick update. Received an email from my bc the other day,we got our developer approval for our design. Next step is to order a second soil test to capture the changes in the levels of our block. Once done, PD can then amend siting, engineering and etc. Settlement of land is next Monday. Hopefully we get to start in July Re: We are building VANCOUVER 33 with PORTER DAVIS 256May 30, 2017 3:10 pm Sgene85 Hi All, A quick update. Received an email from my bc the other day,we got our developer approval for our design. Next step is to order a second soil test to capture the changes in the levels of our block. Once done, PD can then amend siting, engineering and etc. Settlement of land is next Monday. Hopefully we get to start in July Woohoo, that's great news on developer approval, sounds like things are starting to move along for you! Building a Kew 28 with Porter Davis Re: We are building VANCOUVER 33 with PORTER DAVIS 258May 30, 2017 3:26 pm Sgene85 Yes, finally. Thanks Hurrow! Hope everything's going well with yours! We're making progress which is good. Our block will settle in the next couple of weeks and then PD can get the soil test done, we are hopefully putting our plans in for developers approval this week I guess, and then council approval etc after that. I would guess maybe a July or August start date if everything goes smoothly. Building a Kew 28 with Porter Davis Re: We are building VANCOUVER 33 with PORTER DAVIS 260May 30, 2017 4:38 pm I keep thinking about setting up a blog but never get around to it, and no instagram either although I may do that at some stage I suppose as it probably involves a lot less work! We'd had a really hard time finding house designs that we liked and went to a display village near Melton to see a house by Eight Homes that looked like it might be ok on the plan, popped into the PD Kew 28 display and went wow this is exactly what we wanted. Unfortunately we needed to do pretty much all the design option upgrades to have the same structure as the display so there was a fair amount of extra money on top, but that's life. Building a Kew 28 with Porter Davis Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 14010 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11834 |
